What speed control?
  • paDDY
    • Aug 2014
    • 127
    What speed control?
    I'm new to the fast electric and less then a month ago bought a bj 29 and am hooked! I just won an eBay auction for a 32" carbon fiber cat with a Neu Racing 1515 motor. What is a good speed control for this? Will the motor be ok with 5s as long as the speed control can handle it?
  • montymike
    • 774
    180a or greater speed control. Mike
      What kv is it?
      • montymike
        • 774
        Yup jumping to conclusions was thinking it had to be
        A 1y 2200kv on 5s. Mike
        • paDDY
          • Aug 2014
          • 127
          I think 2200? From what I see online.
          • paDDY
            • Aug 2014
            • 127
            Some photos! Any ideas who makes it?
              • 9438
              What is the width? I would guess a 32" TFL cat in Carbon. Nice scoop.
              • paDDY
                • Aug 2014
                • 127
                idk what the width is. I have not received it yet. I might have more pics.
                • montymike
                  • 774
                  Nice...
                  • paDDY
                    • Aug 2014
                    • 127
                    I see the water pickup on the rudder gets tee'd to the esc and the motor. What are your thoughts on this? Should it be ok? I know water will take travel too the least resistance path it can go.
                    • olwarbirds
                      Magic Smoke Wizard
                      • Oct 2012
                      • 1136
                      I run on a Neu 1515 2200kv on 6S and I have used the hobbywing T180 on that setup http://www.offshoreelectrics.com/pro...seaking-180-v3 I do suggest using a prop like a 442 or 642 and work up from there...I personally dont use the cooling line splitters, I prefer seperate lines on my hotter setups. One from rudder and one through hull pickup or use a dual pickup rudder.....that should be a fast boat even if you only go 4S...have fun... DJ
                      • 785boats
                        Wet Track Racing
                        • 3169
                        I don't like Y fittings for the very reason you stated Paddy.
                        The only way to see if it works properly is to have both outlets on the same side of the boat & see if the water streams out at the same rate as the boat roars past you at full noise.
                        I prefer the old into the ESC, then the motor & out the boat myself. Simple & Efficient.
                        Paul.
                          Same hull as my rivercat.....
                          • ls1fst98
                            • 859
                            Was this in florida? I was about to buy it local if so
                            • paDDY
                              • Aug 2014
                              • 127
                              idk, ebay
