SF esc need help
  • darryl whitman
    • 581
    SF esc need help
    hi guys , I have a JAE 21 FE , 1515 y1 2200 kv motor, SF 220 pro + esc
    an 4s 5000 mah bats, abc 1818 prop .I have a program box for the esc, an I set the timing at 10 deg, what is happening is I start out running strong the 1st
    2 laps then she starts slowing down , when I stop an start up again
    she runs strong, then again slows down after 2 laps ,
    any1 have an idea what is going on , plz help.
    What battery? Sounds like the voltage is dropping under load and the ESC is reacting to that. I have almost the same set up as you do but my battery is quite new. What is the LVC on your set up?
      The 1818 is pretty aggressive and loads the motor a bunch, so marginal cells will show depressed voltage after a few laps. That may be enough to prompt the LVC to kick in. I assume the ESC is set to a soft cutoff. If you lower the LVC setting to 3.2 volts that may be enough to finish the heat.
      My JAE with 1415/1Y likes a modded H-7 and runs 12 second laps, GPS in the mid-70s. Less load than the 1818 too, averaging around 100 amps during a 6-lap heat.
      • darryl whitman
        • 581
        thanks Fluid. I'll reset the esc an switch props , what modds to your H7?
        • SirBudman32
          • Aug 2011
          • 701
          I run a CC 1515 2200 with a T-180 on 5s in my Jae turning a 1650 back cut. 86.5 mph.
          Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
            The H-7 is detongued and cupped at the tips to reduce lift. A bit of extra pitch on the last 1/8" of the blade too.
            • darryl whitman
              • 581
              how did you get a T180 esc in your JAE? LOL is your tub widen?
              • SirBudman32
                • Aug 2011
                • 701
                Yeah just a little. But also turned the cooling block on the 180 90 degrees.
