most Reliable ESC
  • rabosi
    • Aug 2011
    • 200
    I am having a problem with the boat cutting out not sure if it is the motor or my 180 Seaking. I am thinking it is the motor so I am going to get the TP, and try that 1st thanks Chris
    If I recall correctly some of the older Seaking 180s had an issue with LVC kicking in too soon. I believe setting LVC lower such as 2.8v/cell and/or setting Lipo cell count manually (not "Auto Lipo") worked. Take care to stop running as soon as decrease in speed is noticed.
      • 7990
      Chris, http://www.ecalc.ch will give you a good idea of the props to use to give the load you want. Depending on you needs, 150 amps would be a good draw to shoot for. The 12" prop is......not the best choice.
      • dasboata
        • Dec 2010
        • 3152
        [QUOTE=Fluid;586464]Chris, http://www.ecalc.ch will give you a good idea of the props to use to give the load you want. Depending on you needs, 150 amps would be a good draw to shoot for. The 12" prop is......not the best choice.
        .Very helpful thanks Jay
        • olwarbirds
          Magic Smoke Wizard
          • Oct 2012
          • 1136
          Jay, thanks for link. I was trying to find that site...agreed 12" prop is rather large and dangerous on motors running the kv we do...unless its a racing plane, the majority of propped planes run 1200kv and lower..plus that would be to much load with the 12" ...look forward to seeing your finished test setup....most rc inline meters only go to 150a there is a way to shunt and get up too 300a. I will try to find the article on how to do this and link it for ya.... DJ
          • MarkF
            dinogylipos.com
            • Mar 2008
            • 979
            #35
            My Hacker motor had a KV of 290.
            Mark
            • jcald2000
              • 768
              #36
              I found that during testing to get stable results it was necessary to run water through the esc and motor, just as in the boat.
              Very easy to do, hose end cap and drill for brass tube apply Goop to brass tube and push thur hose end cap and let dry overnight. Jut barely open the water valve enough to get about 3" of water flowing out the exit tube.
              IMPORTANT!!! Stand behind the test rig, when a prop breaks it goes to the side and forward!! Test outside and away from things you don't want to repair!! Airplane props from the hobby store are only rated for 18,000 rpm.
              Here's how to double the amps on an Eagletree system.
              http://forums.offshoreelectrics.com/...-in-15-minutes
              • dasboata
                • Dec 2010
                • 3152
                #37
                I have changed the design, I am mounting the prop right to the motor shaft as suggested ,,And I will be build a shroud , I appreciate all the help and Ideas all you guys gave me thank you !!
