Phoniex Ice lite how to program with a spektrum radio
  • fas
    There just toy boats
    • 526
    Just like it says I have a ice lite and I am trying to use it with a spectrum dx3s,
    I have tried every thing I can think of to get it to arm with out using a pistix any help would be great
    Fred
    When all else fails floor it
  • jantagg
    • 229
    If it is an airplane controller try setting the Sub-Trim to B100 and the Sub Trim to B50.
      You will want to set these features to the lowest setting:
      Travel: Brake to 150%
      Menu Sub Trim: -100%
      Sub Trim by Wheel: B50
      It should work now.
      • Alexgar
        • Aug 2009
        • 3701
        Jay will this work with all airplane controllers on my spektrum dx3c
        • oscarel
          • Dec 2009
          • 2373
          This may also work, works with Futaba:
          change the 'Throttle Type' to Fixed-Endpoints and follow the instructions in Castle-Lync.
          Fixed-Endpoints
          Fixed-Endpoints will set zero-throttle and full-throttle points to fixed values so that the ESC does not have to learn from your transmitter. If you are using this mode, you will most likely want to change the EPA settings on your transmitter to allow full throttle resolution with the throttle stick. *!**To do this, turn on your TX and set normal mode in the transmitter for a linear throttle curve (0,25,50,75,100). Bring your high side and low side endpoints on your throttle channel down to 25%, plug in the battery pack with the throttle stick at full (it won't start up), then bring your high endpoint back out towards (and sometimes past) 100% until you hear a single tone. Next, bring your throttle stick down to the bottom position and bring the endpoint out from 25% out towards (and possibly past) 100% until you hear the ESC arm. Unplug the battery pack, wait a few seconds, then plug back in and verify that the throttle is working properly.
            I do not know, the only ones I have tried have been Castles.
            • fas
              • 526
              Thanks Jay works like a charm
              Fred
