Castle HV not working after .....
  • fla350tt
    • Nov 2011
    • 340
    I took my new BBY rigger out for test run this morning, boat ran awesome. HV200, 1527 1.5y 825rpm, 12s & oct 2050 prop. it didnt take long to cover the pond on my first full throttle pass and was coasting pretty fast toward shore, I accidentally pushed the trigger to brak to try and slow it down(habbit from cars i guess). I had no motor movement after that. pulled up the log and amp at full thr was 82 amps, when i hit the brakes it shows 345 amps. I had reverse diabled. anyone know why it killed the esc?
    • 7651
    Have you tried resetting the ESC? Not sure why but I have had my 240 come back afterwards.
    Was there any sign of water inside the hull? The sudden slowdown could have tossed a drip at it.
    • fla350tt
      • Nov 2011
      • 340
      Just tried resetting, did not work.
      Boat was dry
        • 7651
        Look up the upgrade that needs to be done to some of these things on castles site. The jarring could've caused this.
        Does it smell smoked??
          • 7651
          I found the service advisory http://www.castlecreations.com/suppo...1201-foam.html
          Apparently the two boards can become unplugged and therefor shutting it down. Just taking shots here.
          • fla350tt
            • Nov 2011
            • 340
            This is a brand new esc that has the foam installed already. I also did the newer firmware update when I did the reset.
            • fla350tt
              • Nov 2011
              • 340
              And no there is no smoke smell
              • oscarel
                • Dec 2009
                • 2135
                Have you tried another motor to verify it is indeed the ESC?
                • fla350tt
                  • Nov 2011
                  • 340
                  Yes
                    • 7651
                    Mmm, I am beginning to question the 3 of these that I have on the shelf.
                    My 240 Ice has been great.
                    • Savage Skidoo
                      • May 2011
                      • 312
                      Well i may not get one of these then for my 2028 , might have to go a different route
                      www.facebook.com/Boaters and Crawlers Durham
                      Durham Off Road Rc Club - www.dorc.ca founding member
