Castle hydra ice hv 200 problem
  • atechbh
    • 388
    Esc has worked perfect and went to use
    Yesterday and won't power up. No beeping or anything. Worked fine last run. Just charged batteries and nothing
    Now.
    Do I need to send in for repair to castle or is there any fix?
  • grsboats
    • 972
    I really don't know what happen to yours but I can say that my new 240 presentend a puffed capacitor on my second run and was substituted for a new unit at no charge...great customer support. It would be good If you can tell us what is your set up Gill
    GO FAST AND TURN RIGHT !
    www.grsboats.com.br
    • atechbh
      • 388
      Only has ever run 6s with 1600 kv motor. In a miss geico 29
      Dual cooler lines and motor and esc
      Never get hot.
      • grsboats
        • 972
        Does it get wet?Are you using the bec? Did you tested it with another motor?Is there any bulged capacitor? Just trying to figured out the issue .Gill
        www.grsboats.com.br
        • atechbh
          • 388
          Has never been wet it is the driest boat I have. Won't beep or anything when plugged in I use a bec battery pack.
          • atechbh
            • 388
            Capacitors look fine
            • Todd Fleury
              • 439
              I had the same issue. Sent the unit to Castle for repair, and received a new one.
              • grsboats
                • 972
                So as stated sent it for repair if its still under warranty time.
                www.grsboats.com.br
                • RaceMechaniX
                  • 2825
                  Can you connect a castle link with battery hooked up and see anything?
                  Tyler Garrard
                  NAMBA 639/IMPBA 20525
                  T-Hydro @ 142.94mph former WR
                  • Todd Fleury
                    • 439
                    Tyler,
                    I was able to use the castle link, but for some reason, the esc freaked and would not initialize. Was really weird.
                    • madmikepags
                      • Aug 2012
                      • 1359
                      problem w the software send it back.
                      We call ourselves the "Q"
                      • atechbh
                        • 388
                        When I plug it into the castle link it doesn't recognize it
                        • smittyj77
                          • 89
                          Smoked Frustraing
                          I have a 200 HV that I just got and was supposed to be Brand new, Its in a 29" Mystic on 4S with Lehner 1940/4 Motor, batteries are Turnigy Nanotech 5600mah 2S. PUt it in the water it went 5ft and quit, motor , esc, and batteries weren't even warm to touch, everything was pretty much air temperature, took it out of the water lifted hatch, both capacitors on it blew right out of it.
                          Pretty tame setup for this caliber of ESC if you ask me. If I knew this was going to happen I would have just bought a $80 Seaking ESC.
                          Has anyone else ever had this happen? And what was the cause of it?
                          • Alexgar
                            • Aug 2009
                            • 3522
                            3914kv on 4s the lehner site shows 220 amps and almost 60000 rpm not tame by any strech
                            • smittyj77
                              • 89
                              The 5ft part is what gets me, theres no way it was drawing that much I never even hit half throttle and just barley got on plane.
