Has any body tried a ETTI 220 amp ESC? What do you think?
Etti 220 amp esc
Great esc and very waterproof as well,my friend sunk his boat with one in lost for two days worked perfectly after he retrieved it and dried it out
just need to count the beeps good when programming but easy to doFC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
Popeye Hydro T600 1400kv 6s1p
? Why not. This is done to reduce resistance and increase the ESC's amp capacity. It also makes it easier to connect 2P setups on the battery side. The motor side is for the same reason, each pair of motor wires is soldered to the same connector for reduced resistance.
BTW this thread is a year old.....
At the OSE store if you look at all the pictures for this 220 esc you will see they use all 4 wires for the cap bank. Check the pictures, you'll see.
http://www.offshoreelectrics.com/pro...prod=etti-E065
I just put a 220 in my 1/8 Scale. Great control so far, it doesn't even know it's in the boat.
I do wish they had left a bit more room between the boards and water cooling nipples.MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169
