I'm hoping someone may be able to hook me up with a link or file needed to update a couple of Turnigy Aquastar 240a esc's, I've look pretty hard with no luck, thanks.
latest firmware update for swordfish240hv / Aquastar turnigy 240a ESC's
Tags: None
If you Email HiFei as I did they will step you through it and give you the files needed. The files are all on their web site but, it's best to email Michelle
Chongqing HIFEI Technology Ltd.
Hello Ray,
Low timing ranges from 0 to 15 degree.
Medium timing ranges from 5 to 20 degree.
High timing ranges from 15 to 30 degree.
Recently, we improve the timing setting of ESC by add more timing options in 2 increments from 0 degree to 30 degree.
If your Swordfish ESC is not the latest firmware, it needs to upgrade it to new firmware and thus can set the new timing by software HiFei V4.03.
What is your Swordfish ESC?
Best regards,
Michelle
I removed my old SF software and then installed the latest version of their software: http://www.hifei.com/list.asp?mid=19Originally posted by millzee View PostI'm hoping someone may be able to hook me up with a link or file needed to update a couple of Turnigy Aquastar 240a esc's, I've look pretty hard with no luck, thanks.
Once I had the new software in there I did the Firmware update first. Once that was done I set my SF240 to 2 degrees timing so I can run a D wind motor without a worry of heat by too much timing.
Thanks Ray, I'll get onto it this afternoon. I appreciate the assistance.
