Cooling Ideas on a turnigy 100a?
  • Stealth Assassin
    • 610
    This big esc will be placed In a small 25" hull so, I am questioning fan cooling... Any Ideas?
  • Flying Scotsman
    Fast Electric Adict!
    • 5195
    I have not found it nescessary. Though I did buy a small fan thinking I might need it. The heat sink does a great job.
    Douggie
    • Stealth Assassin
      • 610
      Douggie
      You running the plush or the HV? I got both.
      • Flying Scotsman
        • 5195
        The HV
        • ReddyWatts
          • 1756
          Depends a lot on your run time as to how well it keeps it cool in a smaller air space.
          ReddyWatts fleet photo
          • Flying Scotsman
            • 5195
            The way I see it. In a small hull all you do is blow more heated air over the esc as normally the hull will be sealed with tape and there is no exchange of air. Water cooling may be a better option, if you require it.
            Douggie
            • Mich. Maniac
              • 1456
              Douggie
              GREAT thinking Douggie. Seems like when lake temps are high the fresh water running through would still far out-cool better than a fan in an allready hot atmosphere. EXCEPT on short runs such as heat racing.
              • Stealth Assassin
                • 610
                Right, That Is what I was thinking guys so, any pics or Ideas on a method of watercooling??? Links to cooling blocks, anything?
                • ReddyWatts
                  • 1756
                  Remember that down south some of the pond water is hotter than what you would think in the good ole summer time.
                  • Stealth Assassin
                    • 610
                    Originally posted by ReddyWatts View Post
                    Remember that down south some of the pond water is a lot hotter than what you would think in the good ole summer time.
                    Also right... It Is hard to run electrics In the summer here In MS It gets hot and humid down here!
                    • Stealth Assassin
                      • 610
                      Douggie
                      What timing are you using?
                      Beep this beep that... I am more Into building hulls rather than listening to beeps. I have the program card and this thing Is still bothersome.
                      • Stealth Assassin
                        • 610
                        Douggie
                        Also do you have to set the throttle every time the esc Is plugged In?
                        • Flying Scotsman
                          • 5195
                          I am using low.
                          I have 3 HV esc ....2 required a PisTix to arm the ESC as when the power was turned off and then on again the ESC would not arm and I do not need to reset the throttle.
                          Douggie
