Turnigy Marine 180 ESC - Reliability Question
  • CanAmAB
    • Apr 2012
    • 29
    I am building my first mono with 6S2P (5000 mAh 6S x 2), Neu Castle 1717-1500kv. It is a Aeromarine Titan 33 hull. Starting with an Octura x448 prop. I have a Turnigy 180 latest version and am planning on using the BEC...
    Should I reconsider, or is this a reliable ESC for this setup? My concern is possibly burning something up because of inferior or under-rated components, ultimately costing me more than if I went with the right equipment to begin with.
    Thanks
  • jamespl
    • 748
    Not sure what it's like on 6s but my 4s setup 2000kv 4074 T180 and a variation between an x645 x642 depending on weather and the T180 works fine for me. You might want to run an rx pack on 6s tho as I know some do.
    • oscarel
      • Dec 2009
      • 2373
      I wouldn't use internal bec on 6s. Also make sure to seal the seams around the case to make sure its waterproof and add extra caps.
      • CanAmAB
        • Apr 2012
        • 29
        I do not have it with me at the moment, but the new version has a separate dangling bank of 3 or 4 caps attached. Are these OK or should they be replaced with different caps, and how many (link?)?
        • jkr
          FE Addiction
          • 582
          For my t180 i've made a cap bank with six panasonic fm 1000uf caps.
          They have the biggest ripple current.
          Remember to take off the bec.
          For more i thing Diesel was running tha same setup on an Osprey 41''.
          • Rumdog
            • 6667
            I use the bec on mine all the time on 6s. It is fine. I believe this problem was worked out with the T-180. They also come with an extra cap bank now too.
            • martin
              • 2881
              Rumdog do you ever have any probs with the Seaking or T180 lvc cutting in like so many have had, can i ask what your settings are re auto cells or set manually & what lvc do you set to. Thanks Martin.
              • CanAmAB
                • Apr 2012
                • 29
                Would these work?
                • Rumdog
                  • 6667
                  You're not going to need extra capacitors. Really, the original esc with only 3 was great. At this point its bullet proof and is compensating for user error with the extra caps.
                  I never use auto detect. I set it for 6 cells with cutoff at 2.8 v per cell.
                  • martin
                    • 2881
                    Have you had it cut off if you set to 3.4v, i have a Seaking 120a that i run with a Leopard 2860 - 4400kv on 3s in a hydro that the lvc cut in straight away. was set manually 3s & 3.4v 60c cells in new condition. I had to run with no lvc & watch run times, i never tried it at 2.8v though.
                    • jkr
                      FE Addiction
                      • 582
                      Originally posted by CanAmAB View Post
                      Yes i use 6 of them.
                      Also i took off the old because i like the caps too bee all the same!
                      • JIM MARCUM
                        • Jun 2011
                        • 775
                        From my personal experience, and numerous threads on OSE, The Turnigy/SeaKing ESC - especially the latest one with extra caps - is virtually bullet proof. Your motor, LIPO & ESC choices are on the money. JIM
                        PS: It's OK to mix caps of different ratings in parallel.
                        JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
                        • sailr
                          • 7128
                          I ran the Seaking T180 (Turnigy is just hobbyking's private labeling of the excellent Seaking controller) in my P mono for 3 seasons. Although only on 4S, it was flawless. LOVED that controller! I have heard many times, however, if running 6S to disable the BEC and run a receiver pack. I'm surprised to hear the success of some here who still use the BEC on theirs when running 6S. It could be Seaking has made improvements since I bought mine.
                          Mini Cat Racing USA
                          www.minicatracingusa.com
                          • oscarel
                            • Dec 2009
                            • 2373
                            I'm glad to hear that too. I'm also still running the older versions and love them as well.
                            • jkr
                              FE Addiction
                              • 582
                              I don't have any experience with the new one as mine is obout 5 years old and still running.
