4 Turnigy ESC goes halfspeed.....
  • numse1964
    • Oct 2010
    • 37
    Hi
    I'm new with the boat bug.
    I have a serious ( for me :-) problem. In my first boat I have build from scrath, I'm using 2 60A ESC from Turnigy with 2 Leopard 28/58 - 2880KV motors and 2 3S 5000mah C20-30 batteries. Radio is a Hitec Agressor CRX 40mhz.
    My problem is that after I programmed the ESC - seems to work well - I got to the lake and then....only 50% rpm's.
    - I have programmed them 1 and 1 and then i used a Y cable.
    When I gor home I checked the motors KV with my RPM/KV reader. It was only 50% rpm's on both of them.
    Then I programmed the Throttle Range setting on the transmitter.
    - Moved the trotteltrigger to the maximum position and then connected the battery pack to the ESC. After 2 sec, 2 beeps can be heard. Then I release the trotteltrigger to the neutral position and hear beep......beep,beep,beep.
    According to the instructions for the ESC there should only be one beep after the trotteltrigger is released to neutral.
    I wonder if the first beep I here is the one mentioned in the instructions and the 3 beep's after is the lipo count ?
    Then I tested both ESC's with 2 diffrent motors. Same results, 50% rpm's on the motors.
    I then programmed the ESC's again, 1 by 1 with the same results only 50% rpm's.
    - first I used a programming card then the transmitter.
    I tested basiclly all settings regarding Running mode, Lipo Cells, Low Voltage Cutoff and Timing.
    Still only 50% rpm's...
    I then orderd 2 new 120A Turnigy ESC's .....I was out of idears, and why not for the future..:-)
    Got them. Programmed the Throttle Range settings on the transmitter then the ESC's 1 by 1.
    Same problem only 50% rpm's !!!
    - then I was about to cry...
    Called in a friend that did i all over again with the same results. Only 50% rpm's from both of them.
    - first we used a programming card version 2 then the transmitter.
    Then we used a seprat battery for the reciver, just in case, then an extra capacitator in the 3 ch, then 3 diffrent 3S batteries ( C rate 30-50)
    Then I tested with a new 2,4 ghz handgun-style radio....Still only 50% rpm's from all 4 of them !!!
    - then I cryed...
    Questions:
    Anybody had the same kind of problem with a ESC ? Turnigy ?
    There is a Reset button on the programcard I have used a lot of times. Is there another way to reset it as much as possible ?
    Programming the Throttle Range setting on the transmitter.
    I have a Genesis cat with a Turnigy 180A ESC without any problems using the same radio and programcard version 2.
    Best regards Henrik
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    Henrik,
    Program the Low Voltage Cutoff Threshold (item 3) to (1) : "No Protection" and watch your runtimes carefully to not overdraw your batteries. This works for all of the T-180's.
    • dana
      • Mar 2010
      • 3660
      Turn the throttle trim on your radio all the way up, then try it
      • numse1964
        • Oct 2010
        • 37
        Thank you. I will try it to night.
        Best regards Henrik
        • numse1964
          • Oct 2010
          • 37
          Thank you.
          Best regards Henrik
          • Boaterguy
            • 1779
            Have you checked the programming/ throttle curve on your TX? maybe it's the programming that's limiting to 50%, also check your DR or EXPO.
            • numse1964
              • Oct 2010
              • 37
              Hi
              I have had some vacation and a lot of work. But now I will try again to solve my ESC issues.
              Bought 2 Swordfish 120A ESC.
              Same problem......still only 50% of the rpm's.
              I will now find a rc doctor in a club who can help me...
              Never mind. I realy like this, so I'm thinking of a HPR C5009 for this fall-winter. Love the building and running :-)
              Best regards Henrik
              • 00-Danno
                GRMM Member
                • Apr 2009
                • 4
                Hi Henrik,
                Did you solve the problem?
                • numse1964
                  • Oct 2010
                  • 37
                  No. I haven't got any idears left for the moment.
                  It realy puzzels me. It's 3 diffrent ESC's Turnigy 60A and 120A + Swordfish 120A that behaves the same way. I tryed the most things regarding the radio but it could be something with the radio.
                  I don't use exp, ABS or anything except default settings with the pistolgrip Hitec Agressor CRX 40mhz.
                  The radio works perfect with my 180A Turnigy....Why ???
                  I even tryed diffrent 4S batteries 4000 mah 40C to be sure there was enough punch from the beginning. Still only 50 % kvm.
                  I resently tryed a cheap HK 2,4 ghz pistolgrip radio. Same problem...
                  I may be doomed on this problem...;O(
                  I hope somebody here with more experience then me, may find a solution :O)
                  Best regards Henrik
                  • hyrulejedi86
                    • Aug 2009
                    • 500
                    Since you mention this I have been facing the same issue on my seaking 60A in my Rio Ep cutting to 50% almost immediatly starting to run full throttle. Hopefully something can be identified besides lipo cut off because I'm going to try that next myself.
                    • Boaterguy
                      • 1779
                      it could be the motor, don't see why but..
                      try the same setup but swap out the motor.
                      • numse1964
                        • Oct 2010
                        • 37
                        Hi
                        I tryed with 4 diffrent motors 28/58 2 pole, 28/45 2 pole, 28/58 6 pole and 40/74 4 pole because as you say, why not...
                        Still the same.
                        Thank you that you mensioned the motors. I will do some sort of excel diagram to sort out what I did and didn't, when I get the time.
                        Tryed the lipo cutoff on 2,8 3,0 3,2 3,4 and off.
                        Still the same.
                        Best regards Henrik
                        • jkr
                          FE Addiction
                          • 582
                          Hello.
                          REVERSE THE CHANNEL2
                          • 00-Danno
                            GRMM Member
                            • Apr 2009
                            • 4
                            Hi Henrik,
                            I am having the same problem with my Turnigy 120. I installed it in my DF29, went 1 lap at full throttle then it died. Let off the trigger, went back to full throttle and only get 1/2 speed now. I'm using a 2.4 Tactic radio. I have the program card as well. Haven't had a chance to set the LVC to off. I will re-program and try this weekend with a different motor as well.
                            • numse1964
                              • Oct 2010
                              • 37
                              Hi Danno
                              I realy hope you don't have the same problem. If you solve it, I will be bery intressted in how :O)
                              - I will try reversing the second channel again as jkr wrote abow in the weekend and get back with the result.
                              Best regards Henrik
