ETTI Speed Control Help
  • steamboatbob
    • Jan 2010
    • 51
    hi guys
    after 9 months in a cupboard at home i pulled out my etti 150 opto and plugged it into my new rigger
    I never had this speedy running properly with my old boat but it has been run before
    problems are i have no arming beeps at all from motor or when i try to enter the Esc into programming mode. I used to run it on 14.4 V and I am now running it on 7.2V i have tried it with a battery connected to the receiver with and without the ESC red wire attached.
    Can i truly say this ESC is gone to the rubbish bin or is there something im missing as i Really dont have the budget to get a new one for a while and budget racing is my way or as i should say it's the way my wife lets me have fun.
    Motor connected
    Feiago 5070kv 540S
    battery
    Zippy 7.2V 5000mah 40C
    Any Help would be very much appreciated
    Cheers
    BoB
    Last edited by steamboatbob; 03-28-2011, 05:04 AM. Reason: put in specs of motor and battery connected to unit
    My budget on boats depends on how much money the wife dosent know i have
  • sailr
    • 6924
    I wish ETTI would come out with a program card/box . I have one that I don't seem to get it to change cell count. I'm trying to use it on an N2 setup but can't seem to decrease the LVC enough to ever have good results.
    Mini Cat Racing USA
    www.minicatracingusa.com
    • martin
      • 2869
      The lvc on the Etti esc is preset with the particular cell count that you choose. To change the cell count or any other mode, Turn on the tx & put full throtle then plug in boat. Youll get a prompt sound followed by tones from 1-6, Each is repeated 3 times for example you get 1 tone 3 times then 2 tones 3 times & so on, In the case of battery type its 1 tone repeated 3 times. When you hear this tone move the stick down to half throttle, That then takes you into the next mode where you geta single tone followed by buzz tones, The buzz tones represent the number of cell lipos you wont so 3 buzzes = 3 cell lipo, 4 buzzes = 4 cell etc. These are also repeated 3 times each, When you hear the one you wont you move throttle stick up from the half position to full throttle & youll get a confirmation sound once you hear that you the move throttle stick fully down. That sets it in then, Then unplug the boat & your done. Martin.
      • martin
        • 2869
        • 785boats
          Wet Track Racing
          • 3169
          Bob.
          I have read somewhere that some ESC's need the battery cell count, that it is already programmed for, to be connected, to be able to make any changes to the program. This includes changing the cell count. The Etti might be one of them.
          So to make it work on 2 cells, you might need to plug in a 4 cell pack & program in the 2 cell count, following Martin's advice. Then plug in the 2 cell pack & see if you have any joy with it.
          Just a thought.
          Paul.
          • Alexgar
            • Aug 2009
            • 3522
            not true 785 i just tested my opto 150 etti which is set to 4s and hooked up one battery(2s) and it went right to beeping and programing, steamboat if you need a copy of the manual pm me or go here i have one so if you want me to try something let me know
            • 785boats
              Wet Track Racing
              • 3169
              Oh well Alex. It's good to know that one is out of the equation.
              Cheers.
              Paul.
              • Alexgar
                • Aug 2009
                • 3522
                ive had nothing but luck with this esc i wish he was online so i could figure it out , i had a hk esc stop beeping and it worked on and off eventually i took it apart and 1 fet was burnt but it still turned the motor ????
                • Alexgar
                  • Aug 2009
                  • 3522
                  also may look into having it repaired(the etti that is)
                  • 785boats
                    Wet Track Racing
                    • 3169
                    Alex.
                    I know it's a pain when things fail for no apparent reason.
                    I only run Himodel GX200A ESC's in all my boats. Of the 5 I've got, one of the early ones had this same problem. Brought it in after a 5 lap run. Temps were fine. Battery was only 50% depleted. Went to run it half an hour later & nothing. No beeps no program mode selection. No Nothing. BEC still worked though.
                    Pulled it apart & nothing visible was burnt & there was no burnt smell.
                    Something on the brains board, or the programing chip itself has failed I reckon.
                    The other 4 are still going strong.
                    Hopefully the Etti is an easy fix. I'm sure you will be able to sort it for Bob when he comes back on line.
                    All the best.
                    Paul.
                    • steamboatbob
                      • Jan 2010
                      • 51
                      thanks guys for your answers but after trying the same thing on 14V i still get no arming beeps just the little red light tuning on is the only thing that tells me my batteries are not the problem and also i checked it on another motor and same problem still exists. So i think this Esc is headded for the bin
                      is the 180 Amp hobbyking esc any good or is it just a waste of time ????
                      Cheers
                      BoB
                      • Alexgar
                        • Aug 2009
                        • 3522
                        i have a t 180 and they are great and great price too
                        • sailr
                          • 6924
                          180 is a great controller!
                          Mini Cat Racing USA
