Are Castle Creations and other ESC makers losing out?
  • LuckyDuc
    Team Ducati Racing
    • Dec 2008
    • 1058
    The P-limited “spec” classes have gained quite a large following over the last 3 years and they are the best attended classes at national FE events. I suspect that these classes are the favorites at many local clubs too.
    I have seen Castle Creations, ProBoat, Turnigy, Seaking, Etti, Aquacraft, Swordfish, YGE, etc represented at these national FE events in the P-limited classes, but is seems that they are not being represented in some local clubs.
    Should Castle and other ESC manufacturers be concerned about this and start lobbying for the “local” sponsorship/ support in the P-limited classes?
  • teach
    • 509
    Sir they are well represented in Pueblo, Co. I would say 75% of our club use castles.
    • Darin Jordan
      • 9446
      Castle is here in Washington, as well. In fact, Brian Buaas works with Castle and lots of us run their stuff.
      Darin E. Jordan - Renton, WA
      • LuckyDuc
        Team Ducati Racing
        • Dec 2008
        • 1058
        Castle as well as the others listed above are represented in our P-limited classes here in WI and IL too.
        I have noticed that some clubs are restricting the choice at the local level, which is fine... It's their club/rules, but I was curious as to how wide spread this practice is.
        • Darin Jordan
          • 9446
          Those clubs that are restricting the choice and limiting thier "spec" classes to factory ESCs are those that CLEARLY understand that the ESC can make a HUGE difference. Unfortunately (depending on where you sit), most do not see this, or don't care, and they are only thinking about what they have in their spares box, as opposed to what would be the most balanced for racing.
          Many of us suggested, when this spec idea first started, that we restrict ESC choice to the factory ESCs, but we were overruled. Not worth the battle. I will use whatever ESC I can afford that is legal, so it's not as big a deal to me. It does, however, put one more factor into getting the best out of the system, and stresses the systems harder by leaving them open.
          Again, not worth battling over for me. I just want to race, and will run whatever rules exist that make sense to me. If they don't make sense, or don't interest me, or I can't afford to be competitive, I won't race the class...
          • sailr
            • 7128
            Totally agree Darin,
            I use the stock ESC's in my spec boats. While our club doesn't restrict using other controllers, I still think the ESC's should be restricted in the spirit of the classe(s).
            It's like saying in an IROC camaro that the engine has to be stock but you can use any carb/injection or nitrous system you want to!
            Mini Cat Racing USA
            www.minicatracingusa.com
            • LuckyDuc
              Team Ducati Racing
              • Dec 2008
              • 1058
              Hence my query. Many have been using a wide variety of ESCs in the P-limited classes over the last three years, and they are currently allowed at national FE race events.
              Does this move by some local clubs to exclude Castle, Turnigy, Etti, etc in the P-limited class mean that there is going to be a national movement to do the same? Those that have been racing in the P-limited classes for the last 3 years and using their ESC of choice would be forced to buy new controllers for all of their P-limited boats. Could such a move hinder the growth and attendance of P-limited classes at a national level?
              It would definitely concern me as a manufacturer like Castle seeing as their products would be eliminated from use in the fastest growing electric racing class.
              • sailr
                • 7128
                I don't foresee any movement to change anything. The clubs restricting the ESC's are in the vast minority anyway.
                Mini Cat Racing USA
                • DPeterson
                  • 991
                  Darrin
                  HTML Code:
                  HTML Code:
                  Hi Darrin, If I may add;
                  The style of hull, hull set up, spec motor selected, prop choice, hardware, driver experience and practice also makes a HUGE difference. The ESC is just one component of many.
                  And actually it was just a few that suggested factory ESC's as there is clearly a majority that is running open ESC's.
                  I really hope we don't have to regurgitate this issue. The sport has evolved into spec racing due to the evolution of the technology and the rules we implemented to control it. The unfortunite collateral damage was the reduction or elimination of the quality classes. Specing the ESC goes against the grain and lowers the quality level yet again. IMO it is the difference between an RC race boat and a toy boat.
                  Doug
                  Doug Peterson
                  IMPBA 19993
                  www.badgerboaters.com
                    Why should they bother? The market is so small that any real effort could use up all the margin they'd make in spec racing sales. We are just lucky that we can use the same basic equipment that the airplane guys do.
                    FWIW I run a Castle ICE100 in my FE-30 with a PiStix. Works great and lets me know that many common spec setups can pull up to 80-90 amps. How long will many 45 and 60 amp controllers last at this amp draw? Some do, some do not. There are advantages to using non-stock controllers besides speed.
                    • Chilli
                      • 3204
                      Very well stated!!!
                      Mike Chirillo
                      www.capitolrcmodelboats.com
                      • LuckyDuc
                        Team Ducati Racing
                        • Dec 2008
                        • 1058
                        Really!?!
                        Maybe you should read this... LINK
                        • Darin Jordan
                          • 9446
                          Originally posted by LuckyDuc View Post
                          Really!?!
                          Dude... take a deep breath... you just pointed out one of the minority clubs... they've had the restriction from the beginning...
                          Our club, and many, many others, have it open... NAMBA, as far as I know, is going to have it open as well.
                          If they are being restricted, it's a local deal.
                          • Flying Scotsman
                            Fast Electric Adict!
                            • 5195
                            Rules, Rules....frankly, as far as an ESC is concerned I do not see the issue, use whatever brand you wish.
                            Douggie
                            • LuckyDuc
                              Team Ducati Racing
                              • Dec 2008
                              • 1058
                              Amen.
