Turnigy ESC programming help
  • ScarabChris
    • Oct 2010
    • 812
    OK I have the Turnigy marine 120s and the program card. I went through the instructions which seemed very simple. I did the programming and the blue light is flashing indicating the card is now programming the ESC.
    But how long does that take? After 20 minutes I figured there was an error and disconnected everything. Then tried to reconnect the ESC again and I got no response from the card.
    So I moved to the other ESC and did the programming. Blue LED is still blinking after 10 minutes.
    Am I doing something wrong?
  • syncronized77
    • Jun 2010
    • 287
    did you setup the throttle points on the ESC with your TX?
    Go Brushless or GO HOME
    • ScarabChris
      • Oct 2010
      • 812
      Nope. I guess I need to do that first?
      • ScarabChris
        • Oct 2010
        • 812
        I'm about to take a sledge hammer to this thing! I am doing exactly what the ESC instructions tell me to enable reverse. The beeps acknowledge the command but no reverse.
        AAAAAAGGGGGHHHHHH
        • ScarabChris
          • Oct 2010
          • 812
          Damn I'm losing it here.
          I got forward programmed.
          I must have went though the reverse programming 20 times and still no reverse. That was a huge thing for me to have reverse. And now I get nothing from the card, not one light lit up.
          • ScarabChris
            • Oct 2010
            • 812
            OK duhhhh never mind I got the reverse. I had the throw turned down on the TX. Jesus I feel stupid.
            But I still get no response when plugging the card.
            • Flying Scotsman
              Fast Electric Adict!
              • 5195
              Toss it, you have a bad card or setup problem, explain how you are setting it up and power sequence.
              Douggie
              • ScarabChris
                • Oct 2010
                • 812
                Hmmm... I'm kinda new to this brushless/ESC thing so I'm not sure what you mean by power sequence.
                I got the ESCs to do what I wanted them to with exception to setting up the low voltage cut off. Thats what I was hoping to do with the card.
                I am powering the card with the receiver battery pack and plugging the ESC into the card and plugging the LiPo into the ESC. This is exactly how the instructions say to do it.
                • britscoot
                  • 721
                  are you using this one? http://www.offshoreelectrics.com/pro...-pcard&cat=136
                  Its so easy with this.
                  • ScarabChris
                    • Oct 2010
                    • 812
                    No its the Turnigy card from HK, the 6 dollar one.
                    • britscoot
                      • 721
                      does it look like the one i posted?
                      • carlcisneros
                        • Jan 2010
                        • 1237
                        correct me if I am wrong, but isn't the Turnegy 120 ESC the same as the swordfish 120 ESC?
                        • ScarabChris
                          • Oct 2010
                          • 812
                          This is the one.
                          https://www.hobbyking.com/hobbyking/...idProduct=2169
                          • britscoot
                            • 721
                            I didnt know that program card worked with the marine esc.
                            This one works and is easy to use.
                            https://www.hobbyking.com/hobbyking/...idProduct=7187
                            • britscoot
                              • 721
                              The seaking card here on ose will work also.
                              I think the one you have is for helis ect.
