turnigy 180 esc problems in df29
  • driftah
    • 757
    my problem is a weird on to me but who knows...anyways I have a turnigy180/seaking 180 amp esc in my df29 on a 9xl with 4s and 5s setups I toss the 5s batts in and then in the water she goes good for about 2 seconds then cuts to 1/3 throttle..then I tried my 4s setup and It didnt do it.Weird because the 4s are 50c 5400mah 2sx2 but the other 5s is a 25c 4000mah combo as in, one pack is a 3 cell and the other is a 2cell,and yes it was fully charged the 5s and yes they are all the same cells and mah Am I missing something or is this just an esc that likes high c ratings or no go....I am baffled? the drive line is smooth as butter as well so not that.
  • JMSCARD
    • Mar 2010
    • 3444
    Your low voltage cutoff is kicking in.... Turn off the lvc.... They work wierd in t180's and it's probably set for 4 cell batts
    • forescott
      Hopelessly Addicted to RC
      • 2686
      Like jms said or could be 100 amps on the 5s config. isn't enough to feed the esc/motor and it is shutting down. My T-180 did the same. Ran great on 4s 30c 7200mah total, but only half throttle on 4s 30c 4000mah total.
      • marko500
        • 861
        The ESCs also have to be programmed for the number of cells you are running. Or they can be set to "auto detect" if you are running different cell counts alot. Do you have a programming box for the ESC? I took a Seaking 120 out of a boat that was running 4s and put it in a boat running 2s without reprogramming it and it did the exact same thing as yours. Changed number of cells from 4 to 2 and it worked fine.
        Mark
        • marko500
          • 861
          On the program box its item 2 "lipo cells"
          Mark
          • forescott
            • 2686
            Sometimes the auto calculate setting acts up too. If thats what your set at, try programming your actual cell count.
            • driftah
              • 757
              ummm
              this is the prog card I got with it and the features 1-4 are the only ones that are accessable to me 1.running mode 2.drag brake force 3.cut off threshold 4.start mode(punch) I dont know how to get into the advanced side of the menu??????? when I hit the item button it goes from 4 right back to 1
              • Make-a-Wake
                FE Rules!
                • 5554
                Program it manually for 5s when you want to run it that way. If you dont have the manual let me know and i'll post a "walk thru" of how to do it..........it takes about 30 seconds.
                • driftah
                  • 757
                  please post.... I run 5s for giggles and 4s for normal running show me the way lol
                  • Diesel6401
                    Memento Vivere
                    • 4203
                    Yes that is the right card, but you are looking at the wrong options. Ignor the sticker on the front and look in the esc manual and you will see the option selection for marine esc's. Their is no "advance" side, marine esc's only have 4 prgrammable functions. The sticker on the front is for car esc's. They are the same boxes, the difference in programming is in the esc's not the box..
                    Read bottom right of page 1 http://www.hobbyking.com/hobbyking/s...7X76598X56.pdf
                    I cut this section out and taped it to the box.
                    - Diesel's Youtube
                    - Diesel's Fleet
                    • Make-a-Wake
                      FE Rules!
                      • 5554
                      OK...........i've done this a hundred times..........this is the easy way to understand and do it.
                      Turn on the TX
                      Put a rubberband around the TX grip and use it to hold the throttle to full forward
                      Now plug in the batts
                      Let it beep a few times..........then it will make a musical set of notes.......leave it alone
                      Then it will start to beep..................first one.........then two......after the "two" beeps, move the trigger to neutral(releasing the rubber band)It will then begin a series of numbered beeps again..........1 then 2, 3, 4, one long, 1 long+ 1 short...........give it full throttle and hold after one long and hold it for about 2 seconds and release to neutral.
                      Its now set for 5s. For 4s full throttle it in the second phase of beeps after the 4 short beeps.
                      • Diesel6401
                        Memento Vivere
                        • 4203
                        Turn on the TX
                        Now that he has the program data sheet for marine esc's he should be able to use the box now with no problem to switch between 4/5s.
                        - Diesel's Youtube
                        - Diesel's Fleet
                        • Make-a-Wake
                          FE Rules!
                          • 5554
                          Cool................i couldnt find a download of it............i swear from what im reading in threads, that the manual programming is so much easier.........................i have it memorized
                          • Diesel6401
                            Memento Vivere
                            • 4203
                            The box works GREAT for me. Stick it in my pocket and head to the lake. Takes 5 seconds to change the programming with the hobbywings. I love that little box!!! Plus it's super nice to use the same box on my T-180 and seaking 120s.
                            - Diesel's Youtube
                            - Diesel's Fleet
                            • driftah
                              • 757
                              it just sucks tho when you keep having to reconnect the red bec wire to reprogram it
