NOTE: WE HAVE RECENTLY FOUND THAT THE PROBLEM OF "FULL THROTTLE when signal is lost" ONLY OCCURS IMMEDIATELY AFTER THROTTLE PROGRAMMING (i.e. FULL THROTTLE WHEN YOU PLUG IN BATTS AND NEUTRAL AFTER THE BEEP). MAKE SURE YOU UNPLUG YOUR BATTS AFTER PROGRAMMING BEFORE RUNNING! Thanks for everyone's help on this one!
The turnigy 180 is a great controller (in my experience so far), but if programmed with throttle channel servo reverse in the "reverse" direction (as with most Tactic and Futba radios), it will give you FULL THROTTLE if signal is lost! This is the case with my tactic 2.4ghz radio and most likely all Futaba radios.
******Make sure you check yours by turning your radio off and monitoring throttle******
Vid of the problem: http://www.youtube.com/watch?v=NvVBXdSGXus
