Turnigy Aquastar Series ESC's
  • blackcat26
    High Speed Junkie
    • Sep 2009
    • 1750
    Baked is correct. I have seen both the aquastar and the swordfish naked. Same same.
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3784
      here's a Turnigy Aquastar cut open: (I removed the water jacket- this ESC is toast)
      There is a light coating, don't know if I would trust it to be water proof.
      • blackcat26
        High Speed Junkie
        • Sep 2009
        • 1750
        I don't like the way they did the fets from the factory, makes the middle board take alot of heat!
        • Make-a-Wake
          FE Rules!
          • 6057
          So its a 4 cap job..................Turnigy marine is two..........although with a higher uf.
          • FighterCat57
            "The" Fighter Cat
            • Apr 2010
            • 3784
            The heat sink goes between the two fet boards, but the layout is a bit confusing. The cooling plate is on the solder side of both fet boards.
            • LiPo Power
              DJI Drone Advanced Pilot
              • 3678
              Thanks, Great Pictures......
              I have one. How did you toast yours????
              Robert
              Canada
              • FighterCat57
                "The" Fighter Cat
                • Apr 2010
                • 3784
                Robert
                I plugged two of them into a Y connector... guess what happened to the controller? Now it just shakes like it's retarded.
                I discovered this when I used the same Y connector and toasted another ESC with the same result... I soon realized that the new Y connector didn't have one of the red wires removed, like all of my others do. Typically, the first thing I do is pull the red wire on one side of the Y connector.
                So there's your PSA and the result of "what happens if...".
                • BakedMopar
                  No Mo Slipah
                  • Sep 2009
                  • 1743
                  Weird I didn't pull any red wire on my Y
