I have this esc http://hobbycity.com/hobbyking/store...idproduct=8946. I would like to use this programming box .http://hobbycity.com/hobbyking/store...idproduct=7187 Does anyone else use this, if so do you have to use the faceplate from the zip file ?. thank's
turnigy esc ?
I have used that Programmer on a Marine 180 with the use of the faceplate from the zip file.
LarryPast NAMBA- P Mono -1 Mile Race Record holder
IMPBA 20481S D-12
You have to be careful. Those two program cards are NOT interchangeable. The Turnigy you refer to is made by Hobbywing and uses the box. The other one somebody showed is for their aircraft esc's only. I have verified that with the factory.
You have to use the BOAT faceplate in the zip file. The Boat esc's program differently than Cars, etc.Mini Cat Racing USA
www.minicatracingusa.com
Originally posted by sailr View PostYou have to be careful. Those two program cards are NOT interchangeable. The Turnigy you refer to is made by Hobbywing and uses the box. The other one somebody showed is for their aircraft esc's only. I have verified that with the factory.
Thank's JIM.
I took mine off.........it didnt change anything.............NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
LEAVE IT ON THERE! It's a ferrous iron ring. It reduces glitching and interference to your radio! It's on there for a reason. Otherwise why would the manufacturer put it there?Mini Cat Racing USA
I believe this is a choke. A sort of 'filter' between the ESC and rx.Originally posted by rchippie View PostIm installing my turnigy 120 marine esc in my rigger. It has a little magnet near the reciver plug that the wire is looping thru. Are you guys leaving the magnet on or taking it off ?.
EXACTLY! Some receivers are ultra sensitive. If you took yours off and it didn't change anything, then your receiver tolerates it just fine. The manufacturer of that ESC is very conscientous and quality oriented...more than any other I have ever known.
Originally posted by Drag Boat Bob View PostI believe this is a choke. A sort of 'filter' between the ESC and rx.Mini Cat Racing USA
For a better understanding of its use, Google it (Electrical Choke). They are used in almost all electrical circuitry i.e. stereo components/TV's/computers etc.
I took the "risk" and took mine off as i said above...............but im using 2.4 ghz..........maybe thats why i have no issues.............NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
