Turnigy 80hv little black wire (spark control)??????
  • justintime2w8
    • 323
    I need to know what to do with this wire, does it get soldered to the red(+) side?
    Thanks for any help.
    Justin
    www.radtekpowerboats.com
  • justintime2w8
    • 323
    Does it precharge the capacitors? it has it's own connector and everything.....
    • ozzie-crawl
      • Sep 2008
      • 2943
      being a black wire and it looks like its on the negative side i would think you maybe just solder it in with the negative bullet but iam no expert
      that can be the problem with some of the Chinese gear, no instructions
      • CornelP
        • 793
        Actually, yes, it is a spark control resistor. You are right, it will precharge, so you have to connect the wire with the resistor before connecting the main cable. See:
          This will save your esc caps from ending too soon..
          I just put a 33 ohm resistor in between aligator clips so I can use it on any esc.
          I will use this for all my 4S+ boats this year.
          • Rumdog
            • 6667
            Gotta love the inexpensive high quality chinese stuff!
              To be fair, the idea came from Schulze Electronics some time ago.
              • justintime2w8
                • 323
                I am hoping they will hold for a while, we will see. If not I will have to spend 3 times these to get german or US
                • justintime2w8
                  • 323
                  Yea these will run the max 12s they are "rated for". So I will zip tie the heatsinks and maximize the cooling and cross my fingers.
                  • DISAR
                    • 1137
                    Ray would it be possible to post a picture of this resistor? The aligator clips are soldered to the resistor, then connect them to the positive bullets (esc+bat) then disonnect them and connect the bullets? How you do that?Thanks...
                    http://www.rcfastboats.com/
