New Turnigy ESC
  • Jeff Wohlt
    • 2740
    And......back to this post. At least a program module! the shrinkwrap???...I think I can handle that mod.
    www.rcraceboat.com
    jwohlt5362@yahoo.com
    • alvinsmith75
      • 635
      Originally posted by motoxbob11 View Post
      I just got a new 240 also and neither size tubing that I got from OSE seems to be able to fit. The tubes are too close together. What is the secret?
      I usually use saliva lube and slide both lines on at the same time. You can also use a small screwdriver or allen wrench and slide it in the tube and carefully pry them apart.
      • bustitup
        • 3072
        its very easy but be very carefull
        slid something into the tubes (the same size as the inside diameter of the tube) and very carefully bend it to the side just slightley
        if you were to mark them 1 2 3 4
        bend 1 and 2 to the left and 3 and 4 to the right.....you dont need much bned to be able to slide the fuel tubing on so bend very little its easy
        • bustitup
          • 3072
          that my freinds looks like they added water cooling and upgraded the old hextronic esc...it also programs with a usb thingy and was a very very good esc
          http://www.hobbyking.com/hobbycity/s...rogrammability
          • hide
            • Dec 2008
            • 188
            For the watercooling tubing I used silicone lube spray on both the pipes and the tubing, worked a treat, was really struggling with them prior to that.
            • sundog
              Platinum Card Member
              • Feb 2009
              • 940
              I'm not too crazy about having just one water tube along one side - like the Etti 150A non-opto (w/bec). Just doesn't seem like it will be as efficient as two - how many cents would another tube have cost them? It cost Etti another repair when mine fried a while back. Methinks they should go back to two tubes like on their opto model.
              Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
