Castle Ice controllers
  • Raydee
    • 1619
    Originally posted by Joe Ford View Post
    Send one of these to me please. I want to see it and will make engineering look at it. Especially now that I'm "one of you" and am getting hooked on boats. Setting up a TT Outlaw 7.5 right now...HV240.
    And yes, we will be doing a boat version of the ICE down the road. Hold tight guys.
    Yeah Baby, that is what we need! One of the Castle guys actually hooked on boats is great. I bet now we (Boaters) will get more attention like the Flyer's get
    By the Way my Ice 75 for one of my heli's came in today...nice looking ESC
    Team Liquid Dash
    • Ub Hauled
      • 3051
      I have o agree with you Ray, it's a very nice looking ESC... can't wait for the Marine version...
      • Joe Ford
        • Apr 2008
        • 101
        LOL!!! It was only a matter of time. I was sent one of the Vac-u-Pickle boats, and tried it out. Instantly hooked. Being from a pylon plane background where 180mph is an everyday occurence I couldn't believe that boat scared the life out of me. LOL Not sure how fast it's going but about 40 I'd say. Now that I've run it every night possible after work I need MORE SPEED. Pond I'm at is flat as a plate of glass every night. Could be 40mph winds (which we get quite often in KS) and still flat water. Protected on 3 sides by trees, and the 4th side by a big berm of earth. Thinking the next one will be a rigger. :) And yep, if you want something done, get one of us hooked. LOL I'm relentless....
        And thanks to you both for the kind words re the ICE. Took us a while to design that beauty.
        Joe Ford
        Product Specialist/Surface Team Manager
        Castle Creations
        • D. Newland
          • Dec 2007
          • 1066
          Joe-There's a little FE race going on in Michigan Sept 17th-20th. It would be a terrific R&D trip for you.
          • Doug Smock
            • 5359
            That's one of the boats from the Hydro Shootout right???
            I was wondering if it would ever see the water again, glad you're having fun with it!!!
            Thanks again for your help with the project!
            Doug
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • domwilson
              • 4411
              Joe, Is it safe to run the hydra 120 LV on 4s with the BEC? I've read some say yes and others say no. Can you clarify?
              Government Moto:
              • tth
                • Apr 2008
                • 1600
                Nice to see you coming into "our" world Joe. Welcome aboard the FE addiction. I have been running nitro boats for many years. FE re-ignited that spark. Thanks for everything that you and Castle have done for all of us.
                • RCprince
                  • Jul 2007
                  • 1684
                  These bad boys even come with a built-in data logger
                  Data Logging
                  Ice brings another incredibly useful feature, extensive data logging capabilities. The controllers are able to measure and record many parameters at sample rates that you choose between 10 samples per second and 1 sample per second. Data points include:
                  * Battery Voltage
                  * Battery Ripple
                  * Battery Current
                  * Controller Temperature
                  * Controller Input Throttle
                  * Controller Motor Power Output
                  * Motor RPM
                  Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
                  • Ub Hauled
                    • 3051
                    Ain't that sweet!
                    • Joe Ford
                      • Apr 2008
                      • 101
                      Only problem is this is the same time as one of our largest events of the year...the NEAT Fair. I will recommend it, but not sure if we have the manpower. We all go to NEAT, and I know tickets are booked way in advance. Will check on it though.
                      Doug
                      You know it. That thing ROCKS. I love it. Like I said though...now I need more speed. LOL You don't know how many times I've thought about connecting those 2s FP 5000's in series instead of parallel. No worries about her ever seeing the water again...she sees it nearly every night and will continue to until I can't hold the radio in my hand from the temps dropping here. Come spring though, she'll be back again.
                      I've run on 4s with the BEC, and I have had it cut out once while doing steady, full throttle circles on the pond. I'm using 2.4 so any voltage drop will do that though. Not sure if the BEC dropped out completely or voltage just sagged a little too much. Either way, officially, I have to recommend using a separate power supply for the receiver and servos. Strictly a matter of safety. I have had a BL 1/8th scale car I just finished go full bore down the road and slam into a mailbox post when the voltage to my rx dropped the slightest bit. Was not pretty...and I'd hate to see what would happen with a boat. I've been using little 2s 800mah lipos with one of the linear BECs off our old Phoenix controllers since that drop out (knew they'd come in handy some day...holding onto them for 2+ years!). Problem solved...
                      I finally "get you guys" now that I'm hooked too. So THANK YOU ALL!!!
                      ICE boat ESCs will have the same features too so you guys can see what kind of current you're drawing, what your batteries are doing, etc. Going to get an update from the engineers and see what they say about when we may have them out. Let you all know.
                      Joe Ford
                      Castle Creations
                      • bustitup
                        • 3072
                        Joe..tough question coming
                        while I am waiting for my 240 HV to return from CC..what do you think of me running my hydra 240 LV on 6s2p? motor again is 1527/1y and batts are 2 x 6s 30c 5000mah
                        and what do you think of using a anti spark arrester to eliminate the big spark on plug in
                        34" sprintcat hull
                        • Eodman
                          • 1285
                          There's a lot of nice things that the Ice may offer .... but at what price point! After losing 2 Hydra 240's this weekend I have to say I am more than a little gun shy in investing in an even more expensive ESC!
                          Not trashing Castle here .... just pure economics!
                          We did it with a Bang!
                          Cats Are Where It's At!
                          • bustitup
                            • 3072
                            Joe this is the spark arrestor I was refering too...some have said use a 1 ohm resister instead of 20 for the 240 hv
                            what do your techs think of this setup?
                            if this works dont you think it should be factory installed?
                            • hebner
                              • 655
                              Bustitup,
                              I have a Aeromarine Team Believer Cat that is same lenght and has same running surface as your Sprintcat, I use Hydra 240LV, 1527/1Y and 6s2p 35C Elite 5000 been running this set up for @ 1 year never had a problem. Knock on Wood! I will be at the Brandon Model Boaters race on 9/20. Our club the Aquamaniacs will be racing at least three classes. You should try to make it.
                              Hugh
                              • bustitup
                                • 3072
                                Originally posted by hebner View Post
                                Bustitup,
                                Hugh
                                That is music to my ears Hugh
                                Few questions
                                R u using castle link 1,04
                                Speed
                                Prop
                                Using spark arestor?
                                What timing
