Dead charger
  • Diegoboy
    • Mar 2007
    • 7444
    Dead charger
    I was charging my ep4200's (2x 6-cells) at 5 amps. first one completed. Started the second one, walked away for a few minutes, (okay an hour) when I got back the charger was dead. The AC input is 120VAC the output of the transformer is under 2VAC. The problem is the transformer. the thing is only about a month old, but I did mod it a bit. What to do?
    It's a Vision Peak Ultra.
  • Diegoboy
    • Mar 2007
    • 7444
    Mods are...
    Cut the AC input, Installed sockets in order to remove the cord when not in use.
    Installed one of these...
    • dirtysouth31
      • 546
      stop the presses!!!!!!!he was charging his batteries people..charger wasnt used to having a battery connected to it.lol...anyways it has a warranty so i hope you saved the box and receipt..call me and ill let you borrow a charger or charge them for ya..
      • Diegoboy
        • Mar 2007
        • 7444
        It's just a BAD day for me.
        Couldn't run the Bud, because work sent me out till after sunset.
        Lipo discharged beyond min voltage, now it's trash.
        Now my charger is dead.
        • Diegoboy
          • Mar 2007
          • 7444
          Box, No.
          Receipt, I think so.
          Do you think they'll honor the warranty after the modding I did to it? You've seen it Dirty, What do you think?
          • dirtysouth31
            • 546
            well i got my flex shaft and rod so i can fix the rudder,so ill be ready...dont cry over broken chargers
            • dirtysouth31
              • 546
              well i still have my box so you do have a box
              • part time
                • 154
                Originally posted by Diegoboy View Post
                Box, No.
                no, did u try using the dc side?
                • Diegoboy
                  • Mar 2007
                  • 7444
                  No, I'll go try that right now...
                  • Mich. Maniac
                    • 1456
                    Did you check the water, choke it? LOL!
                    • Piranha2
                      • 320
                      sounds like some of the secondary winding insulation has been compromised.....(shorting) this can be caused and relieved by temperature....the primary and secondary are wound together, tranformation takes place when the magnetic field induces flux on the ferrite core...........ah, forget it...you need a new one!
                      • Diegoboy
                        • Mar 2007
                        • 7444
                        Wow. It works on DC input.
                        Odd
                        • Piranha2
                          • 320
                          not the transformer, the regulator works on DC.
                          • saleens7
                            • 1130
                            cool..it works...sorry bout those lipos....the sad face thing keeps cracking me up...
                            saleens7, the wookie of rc boating
                            • Diegoboy
                              • Mar 2007
                              • 7444
                              Ya. I liked that one better than this...
                              I'm not quite to this point yet
