I'm kind of lucky and have value hobby.com local so I pick up from their warehouse. They also happen to be an authorized icharger dealer. I also use their gforce batteries and have been reasonably happy. After seeing your vids though I think I'm going to have to pick up some revo's and spc to try.
hv chargers.....what are my options?
I have 2 3s packs I just put for sale.....Originally posted by Jdpb614 View PostI'm kind of lucky and have value hobby.com local so I pick up from their warehouse. They also happen to be an authorized icharger dealer. I also use their gforce batteries and have been reasonably happy. After seeing your vids though I think I'm going to have to pick up some revo's and spc to try.
I found a power supply here at work that puts out 41 amps....for free. Lol32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
Resistors? For what? Don't I just need 12v? I figured our what's 12v out.....Originally posted by Jdpb614 View PostYes that will work. There are tons of write ups online how to do it. I will tell you the 25 watt 2 ohm resistor works best.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
Computer power supplies are load dependent. Therefore a resistor is wired in to act as a load. I would suggest if you're going to mod a computer PSU, read up, be careful, and understand why things are done the way they are.Originally posted by kfxguy View PostResistors? For what? Don't I just need 12v? I figured our what's 12v out.....Last edited by Rocstar; 09-09-2014, 09:01 PM."There's nothing else I really want to do other than get up and build boats." - Mike Fiore
Thanks and will do.Originally posted by Rocstar View PostComputer power supplies are load dependent. Therefore a resistor is wired in to act as a load. I would suggest if you're going to mod a computer PSU, read up, be careful, and understand why things are done the way they are.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
Thx! I actually fell asleep reading on it last night. One guy used the fan across the 5v side and that gave him the load instead of a resistor....I think that's the route I'll go.Originally posted by Rocstar View Post32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
I was using a surecharge 2010 which is not a terrible charger. It could only charge my 2x3s 5000mah packs which I run in series at about 2.5-3 amps. I can now charge the same packs at 10 amps. I know you aren't concerened about time but when you can charge 4 3s packs as 2 6s packs in the same time it took you to charge 1 3s pack you'll want more. I can fully charge said 6s pack in about 25-30 minutes.
Are there any that charge above 4.3v per cell ?.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
A little while back I got a reactor charger (20A)from HK. Not too bad a charger so far and I did discover that I can reset the end voltage on it and it does other stuffI haven't figured out yet. But... unfortunately one day my daughter (15) got sick of it beeping and decided to turn it off, by disconecting from the supply!!! Bugger bec. it fried the balance ports and now it will only read/balance 2s packs. I can still fast charge with it with and as long as I don't need the other balance ports it is ok. Just a bit annoying though! Interestingly I couldn't find it at HK today, it seems to have vanished from their store!?NZMPBA 2013, 2016 Open Electric Champion. NZMPBA 2016 P Offshore Champion.
I ended up getting an icharger. ...it charges much faster than my x4. I like it a lot so far. It discharges about 3 times as fast.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
