Battery charger for 2 - 4S batteries
  • rhgraphix
    • Nov 2012
    • 47
    Like the title says...
    What is the best value charger if I am only going to charge 2 4S batteries at the same time. Also no power supplies. I want one that plugs directly into wall outlet at home
    Thanks for the input
  • LiPo Power
    DJI Drone Advanced Pilot
    • 3678
    http://www.rcplanet.com/DuraTrax_Ony...p/dtxp4245.htm
    http://www.amainhobbies.com/product_...-6S-6A-50W-x-4
    Canada
      The Dura Trax only charges up to 3s, heads up.
      You need to have a price threshold:
      option #1, you can buy two chargers at a lower price per unit but they will only be powered by external DC power source.
      Option #2,if you want to get a duo charger with AD/DC feature, and be able to charge up to 4s lipo, you could possibly pay more than option #1.
      • rhgraphix
        • Nov 2012
        • 47
        Thanks for the info. That HiTec piece would work great. Not bad price at all...
        • 785boats
          Wet Track Racing
          • 3423
          rhgraphix.
          That Hitec charger is only rated to 50W per channel. Although it's probably a good charger, it will not charge a 5000mah pack even at 1C. About 3.5 Amps is all it will charge at for that size pack.
          If you are wanting to charge 2 packs together to save time, (I assume you are) then this one might be better. Basically the same charger under a different name, but rated to 80W per channel, and will charge at 7 amps. Slightly better than 1C. Cheaper too.
          http://www.ebay.com.au/itm/AC-DC-QUA...32b9d76&_uhb=1
          I have no experience with either charger so I can't say whether they are good or bad.
          All the best.
          Paul.
          • rhgraphix
            • Nov 2012
            • 47
            Thanks for the info. This is why I asked. I knew someone would know much more of the technical side.
