This may be a stupid question but will these boards work with 5000 or 5300mah packs I'm going to use a triton eq charger which I believe has a max charge rate of 5 amps. Also are they safe?
parallel balancing board
Good morning
I'll use this parallerboard http://www.buddyrc.com/paraboard-v2-xh-t.html and the charger is icharger 3010 B 1000 W 30 A 10 S http://www.buddyrc.com/icharger-3010b.html .
This is the power source 36 V 1725 W 47 A
Deltaforce 33" cyberstorm 8s Lehner 2250/9 1315 kv/ Leopard 4082 1250 kv .
Balance boards are safe and popular on the flying side of RC especially with the lower mah batteries most commonly being 3s 2200mah packs. I think you'll find with the much larger packs like your looking to charge it will be pushing the limits of the charger and not really improve charge time. With the those size packs it may be easier just to charge by themselves...
I use hyperion 0606i 50 watt chargers and run only 2ea 2s 5000 lipos I usr up aprox 2500mah for a heat of racing and recharge in parallel tales a little over an hour to recharge the batts after a run. The charger is only a 50 watt and It will recharge at 6 amps"Our society strives to avoid any possibility of offending anyone except God.
Billy Graham
