I am trying to put my truck Lipos on my Hyperion charger. They are 2s 65c. When I connect them and try to charge, discharge, or store charge. I get an " too high output voltage" error. I have tried several times with no luck. Any idea what could be going on?
Hyperion charge error
I think the problem is the two cells are to far out of balance. I have the same problem with my nano tec (crap) one cell on my 5s pack is always low after a good thrashing and have to charge on my astroflight where i can crank up the charge rate manually for 15 min then back on to the hyperion to charge and balance, and all is good........... so far! Jay.
Thanks for the responses.
The cells Re balance as I have been using a onyx 245.
The balance board is jxt for two cell.
I discharged the batteries on a separate discharger to 3.5 per cell and tried the Hyperion in all modes. I continue to get the error. The batteries charge fine on the onyx 245. I want to use the Hyperion because of the storage mode that is not available in the onyx.
Also plan Ed to sell the onyx as it is not needed.
Any help is appreciated.KartRacer ~ Dennis B
Delta Force Pirate 35'~Leopard 4092~1480Kv~Seaking 180~2X6S 65C 5000 Mha Dynogy Lipo,Parallel
Well you are probably correct.Originally posted by JimClark View Poststill seems like the balance board to me what brand of batteries are they?
I just looked at the boards are there different kinds of 2s boards? The onyx board is an electrify the cells are integy.
The Hyperion is a just with 2 s port.
They probably offer an additional board that I don't have.KartRacer ~ Dennis B
Well I won't be buying anymore of those batteries as I buying the Dynogy's from MarkF so maybe I will just hang onto the onyx 245 until they die.Originally posted by JimClark View PostMy guess is it takes a jst-xH board same as most HK lipos and that board does not come with the Hyperion normally
Thanks for everyone's input!KartRacer ~ Dennis B
just make sure you get teh correct ones for the charger you might need them for the other batteries also. Not sure what balance tap Mark uses"Our society strives to avoid any possibility of offending anyone except God.
Billy Graham
I have the tap for mark's , charging my 6s Dynogy's, they came with the Hyperion. I had these 2s before I got into FE.Originally posted by JimClark View Postjust make sure you get teh correct ones for the charger you might need them for the other batteries also. Not sure what balance tap Mark usesKartRacer ~ Dennis B
