Need electronics whiz to help fix power supply, please
  • Doug Smock
    • 5264
    This type of power supply normally gives you output voltage as soon as the primary (110) side is energized.
    Check the fuse with a meter. Consider checking the power switch while you're at it.
    So you did check the BACK side of the board for a blown trace?
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • Make-a-Wake
      FE Rules!
      • 5554
      what is the red switch on the back? Is it 120v or 220v?
      The red switch is for 110v or 220v, i have it set on the correct one...................
      • Make-a-Wake
        FE Rules!
        • 5554
        I guess I can check the fuse with a meter, i will have to hook something up to it to put power thru it...................
        I unscrewed the board to see the back of it as best i could and cant see any black marks.................
        • Doug Smock
          • 5264
          This may help.
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • Make-a-Wake
            FE Rules!
            • 5554
            Thanks, I'll go over it when i get home.
            • RandyatBBY
              • 3915
              I have had a small piece of metal in my Rivergate do what you described and it need to be sent back for repair.
              Randy
              BBY Racing
              • LiPo Power
                DJI Drone Advanced Pilot
                • 3186
                When you get the fuse checked the rest
                should be simple.
                Plug in your meter to output of your PS, turn the reader on, turn the PS on.
                This PS when ON, works without any load connectefd to it.
                If all good, you will see voltage on your reader.
                Forget your 12v multi-charger board. Something tells me there may be a little problem there.
                Need to make sure it works.
                Canada
