Looking for input on a good CHARGER/BALANCER
  • Frazzo420
    • Jun 2011
    • 48
    like the title says ..... i have a venom procharger now but it seems to take forever to balance a 2s 5000mah bat (120-160 min)..
    it also seems to charge to almost full then balance which takes forever..
    and when it stops it reads 4.19....4.20 not 4.20 each??? also i dont have a ton to spend but i dont want anything cheap??? this venom charger was almost 100$ and it just seems cheap....
  • Boaterguy
    • 1779
    OSE has some nice hyperion ones, never tried them, but I've heard they are top - end.
    • Stinger9D9
      • 378
      I'm sure Hyperions are great, but I picked up a Duratrax ICE and Electrifly balancer for $40 (!) off Ebay a while ago.
      Before that, I was using a Triton 2 (Tower Hobbies scratch and dent $70) and an Astroflight Blinky balancer ($30 at the lhs).
      Both of those combinations work great. You do need an external 12 volt power source, but you generally do with the higher amp chargers.
      I just looked up the Venom charger, yeah, it llooks like any number of cheap Chinese charger/balancers on Ebay.
      Keep an eye out in the Swap Shop. A Triton jr and Equinox balancer just sold for $30 shipped!!! That's a crazy good deal!
      http://forums.offshoreelectrics.com/...ghlight=triton
      • jkr
        FE Addiction
        • 582
        I use a hyperion eos0606i.
        It is a very accurate charger but i doesn't have lipo storage and battery internal resistance.
        My next one will be an icharger 208b or 308b.
        I thing they are very good , accurate and you can calibrate them.
        • Frazzo420
          • Jun 2011
          • 48
          Thanks for the input those chargers seem a lil on the pricy side hows abt this one from the king http://www.hobbyking.com/hobbyking/s...dProduct=15986 i guess i would also need a power supply also....
          So i just finished balancing my 2s 5000mah bat on my venom charger....
          It took 5200mah
          took 210 min to charge
          but balanced fine
          • Frazzo420
            • Jun 2011
            • 48
            what kind of time is it taking you guys to charge and balance you packs
            • Boaterguy
              • 1779
              I got a turnigy accucel 6, most old laptop power supplies will have the correct voltage, had it for a month or two, still works fine.
              • Diesel6401
                Memento Vivere
                • 4391
                When it comes to chargers its all about the wattage. Most ac/dc chargers are 50 watts which is ok for smaller packs but struggle (take longer due to lower amp charge rate) with the larger packs. They can't meet the demand. I have had a few chargers and my current favorite combo is this:
                Power Supply: http://www.commonsenserc.com/product...4rai3rhfj1cat4
                Charger: http://www.commonsenserc.com/product...4rai3rhfj1cat4
                My favorite charger to date. Charges my larger packs with ease.
                I think tower has that same charger a little cheaper though: http://towerhobbies.com/products/sky_rc/sytm1001.html
                - Diesel's Youtube
                - Diesel's Fleet
                • G-UNIT
                  • 971
                  I have a hyperion and it works great, but some times the batts don;t balance out the same,
                  like you said 4.19 on one and 4.18 on another or 4.17 on one and 4.15 on another.
                  I tried to charged with out using the balencer and after charged then I connected the balencer and got different results ie they then balenced alot closer togeather.
                  how old are your batts and have you ever discharged them and then recharged them?
                  and @ what amps are you charging them at, I;ve expermented with different amp rates and of cource it takes longer at lower amps and at the end I get deffer'ent resulst on the balencing,
                  just my observtions
                  • Frazzo420
                    • Jun 2011
                    • 48
                    I'm charging at 4 amps and yes the batts a fairly new
                    But is 210 min average for this
                    • G-UNIT
                      • 971
                      I don,t think so way to long IMO, whats the max amp charge rate on your charger, mine is 6 amps and I can charge in less then 1 hr,
                      5000mh and when I charge them they take about 2500-3500mh so as you can see I hav;ent been running them down to far.
                      when I hook up the charger it shows about 7.7-7.9 volts left in the batterys,
                      mind you that I'm no expert on this and I even wonder how far I can run the batts down,
                      I don,t think I should run them down to7.4 but I'm not sure, I guess this is a battery ? in that thread
                      • Frazzo420
                        • Jun 2011
                        • 48
                        Good info let's keep the info going
                        • Frazzo420
                          • Jun 2011
                          • 48
                          so i was thinking about this "100$ venom procharger" .... and i busted out my digi multimeter to do some investigating... so i set my venom 2s 5000mah battery to balance...........220min later its done so i check pack voltage 8.41v......so i look at the lcd on the charger and it reads 8.40v and the cell readout was 4.20. 4.20...and when i checked the cells on the multimeter myself cell 1=4.20 cell 2=4.21..............
                          then i balanced my venom 3s 4000mah battery and the results..... The charger read 12.60v cells where 4.20...4.20...4.20......then i measured with my multimeter and the results where pack voltage was 12.57 cells where 4.20...4.21...4.16????????
                          wow i didnt know venom bought cheap ass chargers???????? and then resold them........
                          • Stinger9D9
                            • 378
                            I didn't know anyone expected Venom to sell anything but cheap stuff after seeing the sub-NQD quality line of boats they sold up until the KoS came out:
                            After seeing that lineup, especially the first 3 nothing Venom sells surprises me.
                            • Frazzo420
                              • Jun 2011
                              • 48
                              BWAAAAAA!!!
