Imax charger
  • fighter cat
    • May 2011
    • 23
    Imax charger
    any body ever used one of these chargers any help is most awesome.
    http://www.hobbyking.com/hobbyking/s...idProduct=6478
  • SweetAccord
    Speed Passion
    • 1322
    There are copies and there are fakes and I reported this to HK a while back and it was a pain to prove it to them, but that is why they now list "copy" and "fakes" on their site. IMAX chargers are good chargers, they use the same menu logic as Bantam chargers. If you want look into Bantam chargers also. The E-Station chargers. They run hard and solid as I almost got an IMAX but realized it was a spin off of the Bantam products.
    • sailr
      • 7128
      Evan Chapkis at www.rcaccessories.com is the exclusive U.S. Importer of Bantam chargers
      Mini Cat Racing USA
      www.minicatracingusa.com
      • carlcisneros
        • Jan 2010
        • 1237
        I use the AC6 and AC680 from Hobbypartz.
        they work great for me.
        here ya go
        • siberianhusky
          • Dec 2009
          • 2206
          What kind of charge times using the AC680 on 4s 5000mah packs? Can it supply a full 5 amps at this voltage?
          • sailr
            • 7128
            It depends on the wattage of the charger. That charger is only 80 watts which means you can charge a 4S 5000 at up to just barely 5 amps. 80 watts/14.4V = 5.55A. There will be some loss through resistance of the charge wires, etc. That means you're gonna have about a 1 hour charge time on that pack. If trying to charge two packs at the same time, you're gonna be down around 2+A rate. VERY SLOW
            Mini Cat Racing USA
            • sailr
              • 7128
              This one has 200Watt rating!
              For only $20 more, you can charge your 4S 5000 packs at 13.8 amps! That will cut your charge time to around 25-30 minutes. MUCH better buy but is DC only.,
              Mini Cat Racing USA
              • sailr
                • 7128
                Here is another with 200watt rating. Not sure but Looks like the exact same charger for $20 less?
                Mini Cat Racing USA
                • sailr
                  • 7128
                  It's really maddening on the Hobbypartz site. The don't tell you the watts on most of their chargers. You MUST have enough watts to charge at higher C ratings unless you're just charging small 2S and 3S packs.
                  Mini Cat Racing USA
                  • JimClark
                    • 5913
                    So how are the chargers mentioned above from hobby partz and HK at balancing are they accurate?
                    Jim are you selling these chargers?
                    Jim
                    Billy Graham
                    • sailr
                      • 7128
                      No. I only sell one charger, a small Hyperion that does up to 4S. I sell them to service my customers that buy my mini boats and run them on 3S packs. I can also special order other hyperion chargers. In my opinion, they are the very best chargers on the market. I have one of their new 720 duo's runnning on 24 volts. I can charge two 5000 packs at 20 amps simultaneously! Good stuff but $280 and then you have to have a 24V source. I use two 47A power supplies in series.
                      I have no idea about how accurate those other chargers are. I have two of the hobbypartz chargers and I have cross checked the per cell readings from them with my hyperion battery checker and they are very very close.
                      Mini Cat Racing USA
                      • siberianhusky
                        • Dec 2009
                        • 2206
                        Personally I'm a fan of the Cellpro 10s. But no built in supply for bench use, have to use a PC supply. Another charger would be nice for charging everything the night before. As well as being a pond backup for emergencies.
                        I hate the claims of all this amperage then you find out it doesn't have to watts to charge more than 3.7v at that amperage.
                        • sailr
                          • 7128
                          I've never used a cellpro but have heard really good things about them. You can get a really good deal on a power supply from www.feathermerchantrc.com
                          Mini Cat Racing USA
                          • siberianhusky
                            • Dec 2009
                            • 2206
                            I'm using a hacked PC power supply, it can only supply the one charger though.
                            • sailr
                              • 7128
                              scratch and dent cellpro 10S for $100!
                              Find information, resources and relevant links for revolectrix.com. This domain may be for sale.
                              Mini Cat Racing USA
