is this charger worth the $
  • Flying Scotsman
    Fast Electric Adict!
    • Jun 2007
    • 5190
    If you are looking to charge LI-PO and NI-MH buy Hyperion. For LI-PO only TP or FMA Cellpro. I have 2 Cellpro 4S chargers and they are superb. The new 10S is what I would buy today.
    • Jeepers
      • May 2007
      • 1973
      the hyperion eos1210i will charge up to 12s.
      I have used the cellpro and hyperion charger they are both good quality chargers. I would pick and choose either one!
      I have the 1210i and love it.
      • frostyan
        • Dec 2007
        • 37
        So basically if I want to charger both nimh and lipo batteries the Hyperion EOS 1210i is the way to go. And if i want to charger two lipo packs need two balancer then correct. How about if I just buy two Hyperion EOS 5I DP would that be the same thing It comes out cheeper. Can I put to chargers in one 18amp power supply .
        • FE_Chris
          • Jun 2007
          • 764
          Ryan, Yes you can use both chargers on one power supply, as long as the PS will support your current drain. a 18 amps power supply is pretty good size. That will support two EOS 5i's no problem! Those chargers do 5 amps max/each.
          For what you are doing, and it sounds like you wanna save a few bucks too, the two 5i chargers, with two LBA10 balancers will work well IMO.
          I ordered two of those 5i's, and one of the 1210i's so I can charge anything i'll ever have of any size, at up to 10 amps, and up to four packs at the same time. I don't really think I will ever need to charge anything above 6s, I don't think you will either. But I like the charger, so I got it.
          Fast Electric and Fast Ford's / V8 Mustang Enthusiast
          • frostyan
            • Dec 2007
            • 37
            look what i found were can i get this at EOS 0610i DUO - 180W + 180W, 2x6S for 360W 12S Max.
            • FE_Chris
              • Jun 2007
              • 764
              it's not out yet.....
              • Bill-SOCAL
                • Nov 2007
                • 1406
                [ATTACH]3181[/ATTACH]
                For me, this is the perfect charger. Trouble is it is not yet available here in the US and none of my usual sources can even give me a clue when they might have it.
                However, I can tell you exactly when it will be available, the day AFTER I buy something else.!!
                Don't get me started
                • frostyan
                  • Dec 2007
                  • 37
                  ya that always happens. it saids charges 1-16 cells of nimh is that for each 4mm output so it chargers a total of 32 cells i assume
                  • frostyan
                    • Dec 2007
                    • 37
                    here it shows all the funtion of the charger and it seems the EOS 0610i DUO does
                    not discharge the battery pack . that make me not want to wait for it.
