GREAT deal on power supplies!
  • sailr
    • 7128
    I recently purchased two 47A power supplies that I wired in series to get 24V to drive my new Hyperion 720 duo charger.
    These are GREAT power supplies. Cost? $90 shipped for both! Only $50 for one. There is also a great thread on RCGroups about hooking them up.
    They have smaller supplies also. They are takeouts from big computer servers.
    This is where I found them. I have no business connection to them.
    Mini Cat Racing USA
    www.minicatracingusa.com
  • SweetZ28
    • 1535
    I have one and posted about them up here a while back they are great supplies.
    WWW.PPRSLOTS.COM
    • oscarel
      • Dec 2009
      • 2373
      Another good source is www.serversupply.com. I bought 2 of these that output 1300 watts for $45.
      • chummer
        • 650
        www.feathermerchantrc.com
        Funny, I was just looking at those about an hour ago. Consider getting the new Thunderpower charger so I will have to upgrade my power supply to take full advantage of the charger.
        Not a bad price. 2 of them for $105 shipped to Canada.
        "IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"
          • 9481
          Dang, I was just thinking I need a power supply!
          • Doug Smock
            • 5359
            Hi Jim,
            What did you do to protect yourself if there happens to be a line fault in the unit they had you remove the ground on?
            Thanks,
            Doug
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • sailr
              • 7128
              Doug,
              I just followed their instructions. As far as I can tell, with them wired in series, the second unit picks up the overall ground as I understand it. You have to unground one of them or it's a direct short when trying to go + on one to - on the other. Don't ask how I know! ;-) I could be wrong though!
              Mini Cat Racing USA
              • ksm2001
                • 397
                I purchase 2 of the 47A PS a couple months back from feathermerchant and built a case around them. I run a Hyperion Super Duo3 and a Icharger 106B+, these are great PS and cheap. I removed the ground wire and metal tab from inside of one to eliminate shorting of the units and used a heavier gauge power cord and soldered 2 computer female power cables in parallel instead of running 2 separates.
                Ken
                DF-29,Phil Thomas Super Sport 45, SV27, Xzess 2 Evo, HOTR 32" Cat
                • ksm2001
                  • 397
                  Doug,
                  Jim
                  • SweetZ28
                    • 1535
                    Ken
                    Nice work it looks awesome!!! Looks like you can do some serious damage with that thing.... A Portable electricutioner!!
                    WWW.PPRSLOTS.COM
                    • Doug Smock
                      • 5359
                      Ok Ken it sounds like you addressed my concern internally. Both of the cases on your power supply are gounded to earth correct?
                      How about yours Jim?? The attached pic has me concerned.
                      Doug
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
                      • ksm2001
                        • 397
                        Doug
                        Doug, I did not cut the ground off the cable as in your picture, you can do it and its an easy way but by removing the ground wire inside the case and a metal tab that is connected to earth ground to case on #2 PS you don't have to worry about shorting out the case. #2 PS will not be earth grounded by the power cord but by running the wires that Jim mentioned from + on the #1 PS which is earth grounded to - on the #2 PS which is not. I would think it still has earth ground from #1 PS since they are connected in series, also both negative outputs come from#1 PS, but your making me think on this one
                        I do like this setup because you can run 12V and 24V at the same time for high voltage and low voltage input chargers or unplug #2 PS and you have only 12V to both sets of plugs.
                        Steve, thank you for the comment, yes there is some serious current in these units.
                        • sailr
                          • 7128
                          I understand your concern Doug, but when wired in series, apparently the one grounded unit somehow grounds them both? Not sure though.
                          I built mine into a case where you really can't get into the wiring so I'm not that concerned. I'll try to get some pics for you all later. I have mine set up for both 24V output and 12V output. The new Hyperion 720 DUO3 requires 24V to be able to charge at 20A! Works great! There is still plenty of power supply 'left over' to run another one or two single battery chargers for 4S - 6S at the same time.
                          Doug
                          Mini Cat Racing USA
