Charging Connection?
  • bettaman
    • Feb 2011
    • 58
    Hi,
    Im new to this and have been doing a bit of searching around.
    I have this charger.
    I have these batteries
    These are the leads from the esc
    Now I assume the batteries will fit the lead above as they are both 5.5 bullet connectors.
    The problem is i got the charger and the batteries and there doesnt seem to be a way of using the cables supplied to charge the batteries.
    Do i need some sort of connector? i have read something about EC5 connectors but not sure if im off track.
  • bettaman
    • Feb 2011
    • 58
    anyone?
    • Make-a-Wake
      FE Rules!
      • 6057
      If the batts have 5.5's cut the end off the main banana plug charging harness and solder on 5.5's...............
      • carlcisneros
        • Jan 2010
        • 1237
        OSE here sells the 5.5mm bullet connectors needed to replace/modify the existing ends on the charging cable supplied with your charger.
        • bettaman
          • Feb 2011
          • 58
          Thanks for that!
          I got another issue though. The website says the batteries have 5.5mm bullet connectors. When I look at them they look really small.
          Anyone own these batteries or know enough to tell me if they are actually 5.5mm because I think they may be even smaller than 4mm.
          • Make-a-Wake
            FE Rules!
            • 6057
            Do you have the batteries? They come with 5.5s, measure yours to make sure, if they aren't then you got jipped on the bullets
