Imax b6 charger
  • Woodz
    • 42
    Imax b6 charger
    i have just got my 4s 3000mah lipo and went to go and charge it and it gives me a low voltage error any1 have any exsperience with these chargers?????
  • Alfa Spirit
    • 2183
    Which voltage?
    Power supply or LiPo voltage?
    • Woodz
      • 42
      reply
      i dont know i select balance on the on charger and 2 seconds later the charger says "INPUT VOL ERR" but it charges my 3s packs???????
      • sailr
        • 7128
        Your power supply isn't supplying sufficient volts or amps for the 4S packs. What amps are you trying to charge them at?
        Mini Cat Racing USA
        www.minicatracingusa.com
        • Woodz
          • 42
          3 amp but i turn them down and try to balance them at 1 amp but stil dont work?
          • sailr
            • 7128
            The message you are getting is for the power coming into the charger. What sort of power supply are you using? Hook the charger up to your car battery and see what happens.
            Mini Cat Racing USA
            • Woodz
              • 42
              k ill try and im using a 12 volt mains?
              • sailr
                • 7128
                yep, 12V input to the charger.
                Mini Cat Racing USA
                • Woodz
                  • 42
                  just put it on car battery and its charging at 1 amp thnx so much
                  • sailr
                    • 7128
                    Yep. You need a new power supply if you want to charge off 110V!
                    Mini Cat Racing USA
                    • sailr
                      • 7128
                      You should be able to charge off the car battery at much higher amps.
                      I would suggest you get this charger. It's a bargain. Works GREAT and is both AC and DC. Best deal on the planet and cheaper than a decent power supply!
                      Mini Cat Racing USA
