Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 AC or DC charger - RcBoaters Forum
AC or DC charger
  • BHChieftain
    Fast Electric Addict
    • 2051
    AC or DC charger
    Hi,
    Lookin' for some advice on what type of charger to purchase. I'm planning to charge 4 seperate 2S1P packs...
    I like the idea of an AC charger (either Hyperion AC/DC, or Bantam BC-6 AC/DC)since I don't need to deal with buying either a large AC power supply or an automotive 12v battery. Regarding Duo type chargers, they are literally twice the cost of a single AC charger so I figure if I want to charge 2 batteries at once I'd be better off buying 2 AC chargers.
    Any particular reason why I would need a high wattage DC only charger vs. a 50W AC model?
    Thanks
    Chief
  • AndyKunz
    • Sep 2008
    • 1444
    The higher the watts it can deliver, the faster you can charge your higher capacity/cell count batteries. The other side of the coin is that, if you get a DC-only, you need a battery that can deliver the current. You might want to get a small generator to keep that battery filled up.
    A 50W AC model isn't going to be very much fun in your situation. A 4S pack is going to be about 17V (easy number to work with). 50W is going to limit you to about 3A. If you're charging 5000's, you're going to be looking at 90+ minute full charges. It only gets longer if you use bigger cells.
    However, if most of your running is with one or two charges per pack per day, that may be just fine. You can charge the pack at home - who cares how long it takes? At the pond you can put it on a 50W charger (assuming it's AC/DC) and let it charge half the day. Not too much problem.
    Another thing to look at is if a charger will provide more power in DC mode. This is very common, since the AC->DC conversion is usually where the 50W limit comes from.
    One more point - do you even have AC at the pond? If not, you really want a DC or AC/DC charger.
    Hope this helps.
    Andy
    Spektrum Development Team
    • Drag Boat Bob
      • Apr 2009
      • 304
      I own 2 of the Bantam BC-6 chargers due to the AC/DC capability. They continue to perform very well. However they are becoming outdated in capability. As the newer Lipo batteries can accept a 5c charge rate I wish they had a higher charge rate (only 5 amp max).
      If you do not charge at the water, then this point is moot. As Andy said, who cares how long it takes at home, within reason that is...
      • BHChieftain
        • 2051
        Well, charge time at home still is a consideration, as I don't really want to be charging lipos through the night while I'm asleep....
        What do folks generally use as power for their DC chargers?
        -Chief
        • Jeepers
          • May 2007
          • 2050
          -Chief
          at the lake either a generator or a 12v deep cycle marine battery.
          at home an ac/dc power supply.
          • FloatDaBoat
            Bare Bones Fabricator
            • Sep 2009
            • 421
            -Chief
            I use a 285 ampere Lawn Tractor battery - - much lighter to tote around than a full sized car battery.
            • BHChieftain
              • 2051
              If I have two separate 2S1P identical packs, it is a simple matter to charge them together in serial? (In that case, I'd definatly need more than a 50W charger)
              -Chief
              • BHChieftain
                • 2051
                Ok, I just stumbled across the Bantam BC8DP which looks to be the best of both worlds-- AC/DC charger, with 120W AC/ 180W DC power... anybody have experience with this charger?
                Explore a wide range of Lithium LiPo, and LiFe Batteries for all your Lithium battery needs. Shop now for high-quality batteries and wiring accessories
                -Chief
                • mappo
                  • Feb 2010
                  • 496
                  Hi,
                  Thanks
                  Chief
                  Hey Guy get the Hyperion Duo 111 it charges dual lipo packs at 15 amps and all other battery types, and you can also upgrade the firmware easily
                  Do you know what the biggest problem with the world is?
                  That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
                  • BHChieftain
                    • 2051
                    I'd love to, but the planet seems to be backordered on hyperion DUOs... got any leads?
                    -Chief
                    • Drag Boat Bob
                      • Apr 2009
                      • 304
                      -Chief
                      These guys allowed me to put one in my cart and did not state out of stock.
                      These things do seem to be scarce.
                      • mappo
                        • Feb 2010
                        • 496
                        Hi,
                        Thanks
                        Chief
                        Hey James, try this link http://www.rclipos.com/Chargers.htm ..and use 4U10 and get 10% off. they do have it in stock.. or you can pm Steve on OSE about getting one..
                        • BHChieftain
                          • 2051
                          Thanks for the leads, guys. I have PM'd Steve a few times on these and they are on backorder. I prefer to buy on this site, but I need a charger soon...
                          -Chief
                          • BHChieftain
                            • 2051
                            Hi,
                            Ok, I ordered a hyperion Duo III (sorry Steve you didn't have these in stock...)
                            Looking for a fairly inexpensive power supply. Any thoughts on using this with it? This one is rated to 350watts:
                            http://cgi.ebay.com/New-12V-DC-30A-3...item27aa700b71
                            Or will this one work-- note, I'll be charging 2 x 2S1P 5400mah packs, usually at 1C
                            http://www.offshoreelectrics.com/pro...?prod=dh-92136
                            -Chief
