Salt Water bath?
    I went through all my 4S packs. 2 out of 10 were crap so I can use the rest for sport running and testing. So far I have 4 packs discharged and shorted out, outside. When I get some salt Ican finish them off.
    • jkflow
      • Aug 2021
      • 329
      Might as well use pepper to go with it, has the same effect.
      This salt myth is truly hard to kill.
      If they are discharged, there is nothing else that will change anything.
      • TRUCKPULL
        • 3293
        If this is true, Why did my pack, that I discharged to Zero, Cut open and sliced each cell with an exato knife.
        Puff all cells when put in salt water for 4 days? They also pissed a white foam on top of the water.
        Larry
        • Panther6834
          • Apr 2020
          • 708
          [QUOTE=TRUCKPULL;769324They also pissed a white foam on top of the water.[/QUOTE]
          That was the meringue, for the pie. [emoji854]
          ~ More peace, love, laughter, & kindness would make the world a MUCH better place
          • jkflow
            • Aug 2021
            • 329
            Simple chemical reaction between the materials and salt water, but other than foaming, what did it actually do beside make a mess?
            Answer = nothing.
            I can't make you stop what you are doing, but please understand that it does nothing to the lipo that will make it 'better' or 'safer' or whatever the myth is out there.
            Only trying to educate.
            Salt water as a 'solution' came about in the early lipo days as the conductivity helped discharge the lipo, that is easier accomplished by a simple resistor/light bulb.
            If there is no reaction when you slice the cells open it's already chemically neutral, it will still oxidize, which is normal and yes it will be faster if you submerge but doesn't accomplish anything useful.
            Convince me otherwise. Bubbles or white foam accomplish what?
            • Panther6834
              • Apr 2020
              • 708
              If it wasn't obvious (and, I can't see how anyone could have thought otherwise), my "meringue" comment was meant as a joke...as in, lemon meringue pie. It's called, "having a sense of humor".
              • jkflow
                • Aug 2021
                • 329
                Sorry, didn't mean to quote you but the one right above
                • Panther6834
                  • Apr 2020
                  • 708
                  [emoji1688]
