New to Lipo
  • paparouna
    • May 2020
    • 2
    New to Lipo
    Hello from Greece...i making from plywood and polyester a boat (is my first try,,so be patient) to try using it for fishing..i write dimencions and weight and all hardware inside,,,my point is how decreese weight and thinking to use Lipo...i dont know any about Ah ..Volts,,,so i need your help's...Length is 92 cm....width is 28..and height is 20....Weight whith all hardware is 9.200 kilos......Hradware now....i use this motor..https://www.cornwallmodelboats.co.uk...mfa1115_1.html ...this esc..https://www.lindinger.at/en/cars-tru...-brush-mo-tors ...2 servos https://servodatabase.com/servo/futaba/s3004 and reciver is that,,,https://hobbyking.com/en_us/turnigy-...ceiver-v2.html ,,,motor shaft is 22 cm,,,and propeller is 4blades 45mm...The battery...(what;s why thinking Lipo),,NiMh 12V 7 Ah.....what Lipo y think is ok for run about..40-60 mins??.. at middle speed? i try to upload some fhotos at construction....Thank and wait your opinion....
  • paparouna
    • May 2020
    • 2
    Someone told me i need 3s Lipo whith 6000Mah at least and big C,,over 30...is right?
    • NativePaul
      Greased Weasel
      • 2764
      That is partially correct yes, the most that ESC can handle is 3s so use 3s. The ESC doesn't mention anything about having a low voltage cutoff, and if you run too long and flatten a LiPo battery it will puff up becoming ruined and a fire risk, so i would advise buying a separate LiPo alarm for it, plug it into the balance port and it will beep to let you know when to bring it in before it puffs up.
      The higher your mAh rating, the longer the boat's runtime will be, what mAh you want is personal choice. LiPos are lighter than NiMh for the same mAh, but you want 2 opposing benefits from the change, what is more important to you, runtime or weight reduction, if it is weight get a 6000mAh pack that will give you almost the same runtime as your existing 7Ah (7000mAh) NiMh pack at much lighter weight, or as LiPos are about half the weight per mAh you could fit 2x 6000mAh packs wired in parallel for 12Ah, and nearly double your current runtime but only save a little bit of weight.
      Generally for the fast boats that this site specializes in we would recommend a pack with a high C rating, but you only have a 25A motor and ESC and to avoid scaring the fish your cruising speed will probably be under 10A (worst case 25A / 6Ah is still <5C load) I would go for a low C rated pack (20C is still overkill for you, but the lowest common rating these days) as they tend to be lighter and and often cheaper for the same capacity. There is not a massive amount to be gained here however, so if you have any fast RC toys that could fit the battery in, I would compromise this and buy a higher C pack so you can use it in that too.
