Lipo balancing ?
  • Andris Golts
    • 508
    Lipo balancing ?
    Hi all im using an Astro flight Blinky balancer to re-balance my 4S 5000 mah lipo's. The cell voltages vary between 4.19 v and 4.21v per pack. I realize that all for 4 cells should read the same voltage. What would be an acceptable voltage difference in a 4S pack ? Regards Andris Golts.
  • rol243
    • Apr 2017
    • 1038
    those readings are ok. i doubt that you would get any pack to balance out to 4.2 volts per cell exactly. you might get a closer reading if you tried a different balancer / charger.
    • martin
      • 2881
      Yep i think within .02 volts per cell is good.
        What charger?
        • Andris Golts
          • 508
          Hi Ray i have i use Hyperion EOSO6O6i and EOSO61Oi chargers. Regards Andris.
            Good chargers. There is a way to charge one cell at a time to bring it closer to the others. Larry and I are are pretty AR about balance and try to balance to the 3rd digit if possible.
            Larry uses Hyperion balancers and recently I have gone to ISDT. I also love the ISDT q6 Plus chargers. Got great deals on them last fall.
              Yup.
