need help with battery choice and configuration
  • nicksrc1991
    • Aug 2016
    • 37
    can someone explain 6s2p for me. im tring to decide if i need a swordfish 300 amp esc or a 240 esc. 36 inch cat neu 1527 1250 motor. i believe 6s2p is 4 3s lipos. and i think i could run 2 4 cell making 8 cell with the 300 amp. just curious which may be faster when everything is dialed in. i have the motor already just trying to decide on bstteries and esc.
  • dethow
    Wired Racing
    • Oct 2014
    • 1500
    8s will of course make the boat go faster. Questions is for how long. Do you just want to run as fast as possible for short runs? Or are you looking to run oval or sport racing for extended times?
    Have fun with that....
    • 785boats
      Wet Track Racing
      • 3423
      6s2p can be 2 x 6s packs connected in parallel.Or.
      6s2p can be 2 sets of 2 x 3s packs connected in series, to make 2 x 6s packs. Then those 2 x 6s packs are connected in parallel. So yes a total of 4 x 3s packs connected in series/parallel.
      To make the 8 cell pack, the two 4s packs must be connected in series.
      • nicksrc1991
        • Aug 2016
        • 37
        which is better series or parallel
          • 4340
          Electronically, they serve different purposes. Batteries are wired in series to increase voltage while runtime (mAh) remains the same. Batteries are wire in parallel to increase runtime while voltage remains the same.
