Minimum required Mah for Limited Sport Hydro?
    I was just curious what is the minimum required Mah for running a AQ 2030 motor in my PTSS Hydro? For racing ovals 6 laps plus mill, etc...
    I run a M440/3 blade or a D/T X442. Strut is approx. 3/4" deep or less.
    I thought I saw Mike Ball or someone else run a pair of 2S 3700's in series at the 2014 nats. Is this enough?
    I ask because I usually carry at least 6000Mah or recently 7600Mah but, I think it;s too heavy.
    Advice, suggestions please?
  • photohoward1
    • 1781
    you shouldn't pull any more than 3000mah for the race. any more and the motor will go poof. I used to run a very light boat with only 4200 total. Some might say though that my voltage suffered and some want the extra weight to hold the boat to the water.
    • rightturnonly
      • Jan 2009
      • 143
      Ray,
      I think I ran a single 4s 5000 maybe even less in my Insane 30 at the MI Cup and Nats. I can check when I get home tonight unless someone replies before then...
      John
      JOHN A. GROSS
      MILLBROOK, AL
      Crickety Crack Racing Team
      • T.S.Davis
        • 6266
        You can get away with 4400 mah but those boats run so light you have to add weight to stay on the water. If your going to add weight you might as well add weight that pays you back with power.
        Ty was sporting 8k at the CanAm. He could run twice with no charge.
        Noisy person
          Cool, thanks everyone!
          • ezhitz
            • Aug 2009
            • 466
            Ray at the Can Am I was running 5200mah in my whip and would come back with 40 percent left.
            :canada
            • Chilli
              • 3204
              I'm a 5000 guy also. I tried 4200's in my FE30 and they came in a little warm for my liking.
              Mike Chirillo
              www.capitolrcmodelboats.com
              • byron
                • Dec 2010
                • 65
                along with the mah rating what c rating do you guys run? 4s 5000mah, 40c . could one get away with a 20 or 30 c rate
                  You see, I've got a pair of Mojo GP 65-130c packs from the cup but, they are only 4500mah. I don't want to hurt them by draining too low and I also want to keep the PTSS on the water.
                  • TRUCKPULL
                    • 3293
                    Ray
                    I run a pair of 2S 6,600mAP 65-130C A-Spec's with a Custom 440/3
                    The A-Spec's are lighter and smaller then the Nano 5,000's
                    Larry
                      They are nice packs Larry.
                      • photohoward1
                        • 1781
                        You are not going to hurt them Ray....What do you think your amp draw is?
                        • RaceMechaniX
                          • 3024
                          I run 2 4200mAh packs in parallel, not so much for the voltage or capacity but for the weight. I already have to run an air damn to keep the boat from blowing over.
                          Tyler Garrard
                          NAMBA 639/IMPBA 20525
                          T-Hydro @ 142.94mph former WR
                          • T.S.Davis
                            • 6266
                            That's enough battery Ray but like Tyler said, weight is your friend in the Thomas.
                            Noisy person
                              • 7512
                              Single 4S 5800mah 30C Turnigy......35% (ish) left after a heat.
