lipo battery very hot and swell
  • langevn
    • Mar 2015
    • 214
    hi i have miss vegas duce converted here the set up
    3674 leopard 2200kv 4 pole
    hobbywing seeking 120v3 set up ( 1-forward ,2-4 cell , 3 no protection , 4 timing 3.75 )
    flex shaft 3/16
    octura x442 2 blade
    2 x 7.5 v 5000mh 45c lipo battery
    i ran this boat but after 6 lap on course the motor temp(100 degree) esc (105-115 degree)
    and the batteries hit in between (130-140 degree)
    trying to figure out why the batteries are running hot
  • Luck as a Constant
    Make Total Destroy
    • Mar 2014
    • 1952
    You could be running too long.
    What brand of battery?
    Also, what connectors?
    Usually heat is generated most when battery voltage starts to drop. Try running 5 laps and see if they stay cooler.
    Jmtc
    • langevn
      • Mar 2015
      • 214
      runing the impba course 6 lap
      2 x zippy batteries 7.4v 5000 45c
      bullet 5.5
        Make Total Destroy
        • Mar 2014
        • 1952
        Well, I think you may be pushing it on a series setup with that motor 6 laps.
        But I could be wrong. Just my opinion
        • iridebikes247
          • 1669
          Are they in shrink wrap, or are they the hardcase packs?
          Zippy packs are usually pretty good imo, but as Luck said it might just be a bit much. BTW Turnigy started making a 60c "heavy duty," pack, that I have ran very hard, another forum member has too and they're fantastic. Something to consider.
          • oscarel
            • Dec 2009
            • 2373
            5000mah probably isn't enough to make 6 laps on a regular course. How much are you putting back into the lipos? I wouldn't go less than 7000mah. If you're racing you'll need to have enough for 7 - 8 laps, 1 start, 6 race and maybe 1 cool down or penalty.
            • langevn
              • Mar 2015
              • 214
              ok thank
              • langevn
                • Mar 2015
                • 214
                ok the batteries i have right now are softcase zippy 5000mah 2s 45c 7.4v and iam looking into these batteries AGA POWER 6200mah 50c 2s 7.4 will these do ok >??
                need your opignion
                • Maximus
                  • Jul 2015
                  • 47
                  Too much prop end of story
