NIMH batteries with brushless setup, yes or no?
  • boilo56
    • Aug 2014
    • 390
    I would like to know your opinion about that. i have alot of NIMH batteries from traxxas, can i use them without worries? My current setup is Pursuit, mambamonster 2 ESC, stock motor(1620kv), prop will be octura x442, or grimracer 12x55.
    Thanks for your advices!
    • 7512
    What voltage and capacity are they?
    • boilo56
      • Aug 2014
      • 390
      They are 8.4volts, and from 3000mah to 5000mah.
      • JimClark
        • 5913
        Only problem is your esc may have a low voltage cutoff for lipos. If you can disable that or lower it a lot there will be no issue
        Billy Graham
        • boilo56
          • Aug 2014
          • 390
          I can program it for NIMH with castle link.
            • 7512
            You will be bored out of your mind with the speeds you will get unless you hook them in series but that would be limited by the voltage rating of the ESC.
            • boilo56
              • Aug 2014
              • 390
              Esc can go up to 6s/25.2v. 3x 8.4nimh=25.2v.
              • Luck as a Constant
                Make Total Destroy
                • Mar 2014
                • 1952
                Maxing out your esc voltage limit is a bad idea. Not to mention you aren't gearing things down. It's direct drive in a boat = more stress on components.
                • boilo56
                  • Aug 2014
                  • 390
                  I'm not saying that i will put 21cells in it, it is just to tell the max input of the esc. i'll probably run two of them in serie, for a bit over 4s.
                  • Make-a-Wake
                    FE Rules!
                    • 6057
                    It will work with two 8.4's in series. Use the 5000's if you have several for best power/runtime.
