Glacier rc packs fail
  • Luck as a Constant
    Make Total Destroy
    • Mar 2014
    • 1952
    #31
    Kevin. Once they're both supposedly storage voltage, I'm gonna hook them up to my other charger and see what it says.
    Then I'll try re charging and see where that gets me
      Make Total Destroy
      • Mar 2014
      • 1952
      #32
      You guys keep me level headed. Thank you for that lol
        Make Total Destroy
        • Mar 2014
        • 1952
        #33
        I've hit an hour with my second pack and the charger hasn't stopped so I don't believe a timer to be the culprit.
        The first pack seems to be worse, as my charger terminates the cycle weather it be storing or charging.
        Here is the first pack on my other charger on storage mode
        Maybe my new i charger is junk?
          Make Total Destroy
          • Mar 2014
          • 1952
          #34
          Also, I thought I would be able to charge at 20 amps. It would only charge these packs at 13 amps at the most
          I'm so utterly confused at this point.
          Here's the power supply Joel made me
            Make Total Destroy
            • Mar 2014
            • 1952
            #35
            Guess I'll just try charging on my old crappy cheap charger.
            • kevinpratt823
              • Aug 2012
              • 1462
              #36
              Fyi, chargers have max charging amp output, but also max wattage output, so as the cell count goes up so does the wattage. Your charger is rated to charge @20 amps, with a max of 300watts, so it will charge a 4s at 20 amps, but a 6s @ 300watts will only get up to about 13 amps. 300watts divided by 22.2v=13.51amps
              Sent from my SCH-I535 using Tapatalk 2
              My private off road rc track
                Make Total Destroy
                • Mar 2014
                • 1952
                #37
                Ohhhhhh
                Well that makes sense. Thanks man
