How I made a 3p battery harness.
  • rearwheelin
    • 1941
    Using 8 gauge , 6.5mm and 8mm bullets.
    First I tie then tin.
    Then I trim a notch for the bullet to go in.
    I solder using only this method. http://youtu.be/l_DY7YjKdZ0
    --Albert Einstein
    • 5554
    Not sure what kind of harness that is, looks like a 3 cell SERIES connector. so if you are running 3s lipo(as an example) you would be running 9s.............I think, it looks very unique...........but not like parallel
    • rearwheelin
      • 1941
      It is for hooking them up in parallel for my Team Believer ! I should have made it clearer in the OP ! My bad I mainly wanted to show how easy it is to join 8 gauge and bullets using a torch .
      --Albert Einstein
        • 5554
        Your soldering and creating skills are very good but it still seems like it will not work in parallel.................it looks like a series connector. Maybe someone else will post.................maybe im nuts.................
        • rearwheelin
          • 1941
          I suppose I could series the packs first and then plug into the harness, that would work !
          --Albert Einstein
          • rearwheelin
            • 1941
            This pic is better. You can plug 1-3 matched packs anywhere on the harness !
            --Albert Einstein
