charging in series
  • urbs00007
    • 857
    charging in series
    I'm going to run my 4 3-s battery packs as 2 6-s packs. they have been cycled numerous times and are close in voltage and resistance. if i hook the 2 3-s packs up to my cellpro charger as a 6-s pack and plug the 3-s balancing leads to the charger, will that work?
    I do this all the time. BUT, you have to make a balance adapter to put both 3s balance leads into the one 6s on charger. You have to use the one common #1 lead for both packs.
    • kevinpratt823
      • Aug 2012
      • 1462
      I do this as well, I'll post a couple pics from phone in a few. You need to pay very close attention to a few things. JST connectors are the easiest to deal with, the prongs are all the same, as in prongs 1-4 on a 3s port are the same as 1-4 on a 6s port. You can actually paralell balance (4) 3s packs on a 6s board if you force the other 3s packs into the first 4 prongs on the 4,5, and 6s ports, it's not a hard fit at all(you obviously have to make up paralell charge leads as well). So for series charging, you can plug the second pack into the last set of prongs in the 6s port, with the other 3s plugged into the 3s port, but the pack in the 3s port, HAS TO BE THE PACK WITH THE NEGATIVE LEAD GOING TO THE CHARGER. If you don't hook these up right, you will cook the balance board. I actually got some real nice balance leads like this http://www.ebay.com/itm/331139173123...%3AMEBIDX%3AIT, you still have to make sure the pack with the negative lead to charger goes in the port with the negative to prong 1. This seller has a TON of different configurations for all kinds of series and paralell charging. All of this is at your own risk, of course, but once I shorted a few balance boards I got my system down well.
      My private off road rc track
      • kevinpratt823
        • Aug 2012
        • 1462
        Sent from my SCH-I535 using Tapatalk 2
        First pic is series charging a pair of 3s as a 6s with a regular board, notice I removed and insulated the negative wire from the lower balance connector to avoid confusion. The pack plugged in to the top 3s port has the negative power wire to the charger, and the positive to the negative of the other pack for series connection.
        Second pic shows the balance adapter I bought, charge lead arrangement is still critical. The adapter is plugged in to another set of 6s paralell adapters, I trim out the plug so I can easily fit 4 and 5s packs in, as long as the negative is all the way over on the side the arrow points to, leaving the last pi or two open.
        Last pic is charging (8) 3s at once in series paralell. (4) pairs in series as 6s each, then all (4) pairs in paralell. At a total of 40 amps, (10 amps to each 6s pair), these 8 packs are charged/balanced in 1/2 hour.
        Again, any of this is AT YOUR OWN RISK, just wanted to share what I have been doing.
        • urbs00007
          • 857
          charg
          First pic is series charging a pair of 3s as a 6s with a regular board, notice I removed and insulated the negative wire from the lower balance connector, otherwise it's a dead short to a positive from the one above it. The pack plugged in to the top 3s port has the negative power wire to the charger, and the positive to the negative of the other pack for series connection.
          thanks, so you remove the neg lead from the connector and just tape it to the battery wire so you can convert back to 3-s if you want?
          • kevinpratt823
            • Aug 2012
            • 1462
            I have edited the previous posts. I apologize, technically, you do not HAVE to remove the negative lead, but after cooking a balance board or two because I got plugs mixed up, I pulled the negatives to simplify it for myself and limit confusion.
            • kevinpratt823
              • Aug 2012
              • 1462
              This is what I meant about using the 6s parallel lead for 4s
              • urbs00007
                • 857
                charg
                now I'm confused. in earlier picture you showed one the neg leads removed from connector. in last picture you show both neg leads in connectors. can you explain why?
                • kevinpratt823
                  • Aug 2012
                  • 1462
                  Earlier picture was (2)-3s packs in series as a 6s. This picture was 4s packs in parallel, charging as 4s. I just showed the last pic because I mentioned it in the earlier post. In series you are stringing the cells together end to end, in parallel you are stacking them and making all the cells common. If you only care about series charging your single pair of 3s then disregard that pic, but I would suggest you get a good understanding of how both work, and the difference between the two.
                  I apologize, technically, you don't have to remove the negative on the balance lead if you configure things properly, but I do it to help avoid a mixup between the one that goes in the 3s port(with negative power lead to charger) when I connect them.
                  FWIW, if you look closely at the series balance connector in the middle of the three pics I posted earlier, you may notice that the negative coming from the 3s adapter plug on the right(soldered directly on to the same spot as the negative power lead inside the pack) goes directly into the same pin as the last/4th wire from the plug on the left(which is soldered directly to the same spot as the positive in that pack, which is now plugged in to the negative of the previous pack anyway). I remove the negative wire on one pack to avoid confusion on which one goes in the 3s port so I don't mix them up , then I identify the positive charge lead from the other pack with black tape or something so I know that that is the lead that has to make the series connection to the negative of the other pack
                  • kevinpratt823
                    • Aug 2012
                    • 1462
                    I apologize if I have overcomplicated this for you, feel free to disregard all I said and seek a more simple explanation, just trying to help you understand and maybe avoid any shorts.
                    • urbs00007
                      • 857
                      charg
                      i understand that both 3-s packs need to ground their black leads to the 6-s ground lead, right? in that middle picture, how is that accomplished? in that adapter are the ( 2) 3-s balance connector neg leads joined to each other? I'm not that good with batt connectors, so bear with me. thanks, john
                      • Luck as a Constant
                        Make Total Destroy
                        • Mar 2014
                        • 1952
                        charging in series
                        Why not just charge in series?
                        Buy a series balancing board, and charge all 4 as 3s at once?
                        • urbs00007
                          • 857
                          charging
                          because i want to treat the batteries as one 6-s pack. they are taped together and i want to avoid having to disonnect power leads to charge. trying to simplify , thats all.
                            Make Total Destroy
                            • Mar 2014
                            • 1952
                            Sorry what a meant was parallel.
                            Parallel charging... Sorry for the confusion there
                            • kevinpratt823
                              • Aug 2012
                              • 1462
                              Bear with me whyle I type/edit a minute........No, this is kinda what I was trying to warn you against, re-read the last paragraph of my last post first, but I'll try to explain it a bit better. The pics I'm about to post are from the Revolectrix manualhttp://www.revolectrix.com/support_docs/item_1431.pdf
                              Now, look at it this way, the charger looks for the negative, then a node at each cells series connection, it counts from neg, to cell 1,2,3 etc., all using another wire as a reference. Each node can be either negative or positive depending on which other wire you're using as a reference. If I test across node 2 and node 3, node 2 would read as a negative, if I test across node 2 and node 1, then node 2 reads as positive, can you see that? So when you look at the 6s diagram, consider that pack A is cells 1-3, and pack B is cells 4-6, pretend you stacked another 3s diagram directly on top of this one in the same orientation, and made the series connection of pos. to neg. with the power leads, the negative for pack B on top now becomes the same wire as the pack pos. from pack A, which is represented as node 3 in the 6s diagram.
