Trying 6s and props
  • Zen
    F1 junkie
    • 123
    Trying 6s and props
    Been doing some research about this question but found no definitive answer. I have a hornet f1. Basically only the hull is a hornet. Everything else was stripped. I added a 3650 2990kv 6d
    On a os leg and a swordfish pro120a esc. I'm using 3s 4500mah 30-40c discharge batteries, the question is can I use 2 3s batteries in parallel to run the set up on 6s safely? Also I'm running a oct x438 prop, it's quick but I want it quicker. The temps are luke warm using it. What recommendation would be for the next few sizes to try to get where I want to be.
    Doesn't matter, real or RC, boats are just a hole in the water where you throw your cash.
  • Make-a-Wake
    FE Rules!
    • 6057
    "the question is can I use 2 3s batteries in parallel to run the set up on 6s safely?"
    Hey Zen, firstly, If you run 2 3s packs in parallel you wont increase voltage, just mah and runtime. If you run them in series you will increase voltage to 6s and mah stays the same. i would not RUN THAT MOTOR ON 6S. You may be able to simply run a prop with more total pitch like an Octura x440 or an x637
    • Zen
      F1 junkie
      • 123
      Ok thanks. I'll take your advise. I'll try a new prop.
      • Zen
        F1 junkie
        • 123
        What motor would you run on 6s
        • Make-a-Wake
          FE Rules!
          • 6057
          Dont know why you want 6s in that thin hulled boat, but if so I would recommend this motor:
          http://www.hobbyking.com/hobbyking/s...ess_Motor.html
          Who knows, maybe the extra weight will make it run more stable.
          • Zen
            F1 junkie
            • 123
            That took me to a lipo pack
            • 704Authentic
              • Nov 2012
              • 178
              Wanted to see what motor you would recommend, the link is to a Turnigy 5000 lipo.?
              AquaCraft UL-1 59mph.
              Motley Crew 61mph.
              JAE 21FE ~~~ 70 MPH Club ~~~
              • Make-a-Wake
                FE Rules!
                • 6057
                Sorry, fixed it now:
                Here it is again
                • Zen
                  F1 junkie
                  • 123
                  I'm using 3s now. And 6s would not be safe. How bout 4s. Will proformance gains be increased?
                  • 785boats
                    Wet Track Racing
                    • 3423
                    Zen.
                    Even on 4s it will be turning at over 44,000 revs. Way too much in my opinion.
                    Here's a good chart to help you find the right kv motors for the different voltages. The lower end of the ranges for sport boating & the higher end for racing. But around the middle is a good all round set up.
                    • Zen
                      F1 junkie
                      • 123
                      Thanks. This is the Chart I am looking for.
