wath means wen only the wires and bateries hot and the motor e esc continuous cold
    • 5554
    Wires seem big enough, your 4mm bullets need to go away and change out for 6mm to match the others.
    • Joselindo Oliveira
      • Mar 2014
      • 11
      its a good idea for all my boats turn all jacket with the rigth size to help water get out
        • Mar 2014
        • 11
        i will change the 4mm bulets, its just the wires get hot not the motor and not the esc, this is the first time in one boat of mine
          • 5554
          Based on the picture you posted it looks like you can cut off about 3 inches of ESC wire. Cut them as short as possible where they will still hook up obviously.
          • kevinpratt823
            • Aug 2012
            • 1360
            But do not cut the wires from the motor itself. It can be done, but you would have to treat the new ends to remove the clear lamination.
            And yes, you should turn all water jackets so the water comes out the highest spot. It will mostly help with motor cooling, but may help with wire temps s bit too.
            Sent from my SCH-I535 using Tapatalk 2
            My private off road rc track
              • Mar 2014
              • 11
              hi guys this is the photos from new change with the wires ( i have try to change the direccion of the motor cooling but its very sealed)IMG_2108.jpg
                • Mar 2014
                • 11
                and the wires not so warm up, tanks guys for the help
                • kevinpratt823
                  • Aug 2012
                  • 1360
                  Nice job, that looks much better! You should be able to rotate the cooling jacket around the motor, you could spray a little WD40 at the ends to loosen the O-rings up a bit, personally I would make sure it goes the way we described, even if you have to rotate the whole motor to another set of mounting holes.
                    • 5554
                    Looks great, now try the 8400 batts and the 6s batts in parallel, should pick up more speed and run cooler still.
