Hobby Kings Awesome Soldering Jig!!!
  • Mad Racer
    • Nov 2013
    • 140
    Every now & again you come across a handy tool for r/c.
    This one I saw the other day while I was looking on the H/K site when placing a order and was cheap enough to give it I go I thought. Up to now I have got past all these years or many years with a pair of long nose pliers and a rubber band as my Dean connector jig BUT this blows everthing away yet so simple.
    It holds wires for you when you are tinning them in solder, Holdes male & female Deans connectors as well as 5.5 mm Bullets for bigger packs like 4S & 6S packs. Made out of Carbon fiber and has a strong sliding spring plates to grip them.
    I just did these 2 new 4200 batteries and was a breeze. Care still needs to taken but so much easier.
    https://www.hobbyking.com/hobbyking/...dProduct=46741
  • flraptor07
    • Aug 2013
    • 2451
    I've got a couple of those, ya gotta watch cause those aluminum posts come loose and strip the holes. This is the best and handiest jig I've ever had. http://www.ebay.com/itm/The-Jigs-Up-...item43cfd5db5e
    • Mad Racer
      • Nov 2013
      • 140
      Well I be Dame .
      If I have problems with this I might purchase that one but post will expensive with international freight I say.
      Thanks
      • flraptor07
        • Aug 2013
        • 2451
        Originally posted by Mad Racer View Post
        Well I be Dame .
        Thanks
        You might check around there, you might find it local. Check Ebay Aus.
          Wow!
          • TheShaughnessy
            • 1419
            We had a jigs up in the shop I used to work at. Awesome little helper, a set of helping hands plus a jigs up and you will find soldering so much easy
              • 9438
              A few pennies or less gets you a jig that you just add weight to
              • Spartanator
                • 1060
                I suck at soldering... but When I atempted to solder I bought a Jigs up. Seemed to work for someone who knows what they are doing...lol
