Dumb thing of the day
    I went to do more trial runs with my Zippkits JAE 21 rigger today. I was using Grim 4s 5000mah, after the first run ( 1'32") , I brought her in to check temp and everything else with the intention of changing to a fresh pack, well I ended up putting the SAME ( they are all yellow, what can I say??) one back in and ran for another 2 minutes or so, the end of the story is that the voltage reading was at a all time low of 3.5v/cell. The HYPERION EOS SENTRY tells me a reserve of 5%.
    Is this battery history??
    The temp on the battery was 130* and is not puffed, still hard. I charged it back to storage now.
    I rarely run my batteries below 20%. Brain wasn't working!!
  • urbs00007
    • 857
    I did worse. ran 2 3-s in series dinogy 65c. the prop was bent, didnt realize . battery temps 130. puffed. 3.18 volts per cell. went down to normal and charged and balanced fine, but dont expect much life out of them. who knows?
      I think the danger zone is below 3.0v. Safe zone is above 3.3 or so. Your fine, I wouldn't worry about it.
        Guess we have all done things we are not proud of!
        Thanks, I should see in the next few days, I can tell you the Grim packs are pretty amazing. I thought for sure it will puff, but still hard as a rock---not that it is necessary an indication of how the actual condition is.
        • photohoward1
          • 1781
          Don't worry about it.
          • rickwess
            • Apr 2013
            • 777
            You're fine.
            • capnswanny
              • Feb 2012
              • 867
              Ditto, no worries....
              This is NOT a toy?!?
                Originally posted by rickwess View Post
                You're fine.
                Thanks for the assurance!
                ( I wouldn't mention the time that I hooked up two 4s in series thinking that I was hooking them up as in parallel )
                • capnswanny
                  • Feb 2012
                  • 867
                  Sounds like my love life.....hot and fast...for a few brief moments of bliss!...
                    Thanks! I didn't realize that until I got home, all the way while I was driving I couldn't understand why the battery was depleted so much...
                    Ah yes, feel good while it lasts....
                    • rickwess
                      • Apr 2013
                      • 777
                      I've had two packs go to pretty much zero and I was able to nurse them back to a state that the charger could charge them "normally". I needed to turn off the balancer setting and fool the charger that they were 1s, 2s and 3s until i could charge with the balancer as 4s. With the balancer turned off, it's 2A max charge for a 120 seconds. Needless to say it took many, many of these short sessions to bring them back.
                      Now how they got that way is the sad story. I had put the batteries on a storage charge, but when the charge was complete, one of my helpers just turned off the charger but left the batteries plugged in. It was the next day before I noticed.
                      • Doug Smock
                        • 5359
                        Keep an eye on those packs fellas. You may or may not notice a capacity loss, but it's there.
                        D.
                        MODEL BOAT RACER
                        IMPBA President
                        IMPBA 19887L CD
                        NAMBA 1169
                        • rickwess
                          • Apr 2013
                          • 777
                          D.
                          I have been. I haven't noticed anything yet in the last year. I did run them through 3 slow charge/discharge cycles on the charger once they were nursed back.
                            Thanks for sharing, I wonder why the charger would allow reverse flow?
                            D.
                            Yes, I am, thanks for the heads up/reminder!
                            That is no simple feat---to nurse them back. Don't think my charger would allow me to turn off the balancing board, I use DuraTrax Ice charger and it needs external balancers like the ones from GREAT PLANES sold @ Towerhobbies. ( http://www3.towerhobbies.com/cgi-bin...&I=LXMGS7&P=SM) It won't go into charge mode without this connected.
                            Glad that you didn't see a drop in capacity though.
