breaking in batteries
  • morewattsnow
    • Oct 2010
    • 236
    What with a lot of manufacturers recommending that packs be broken in at low discharge rates for the first few cycles, I built this. P1010202.jpgP1010201.jpg Each bulb draws about 4.2 amps at 3s so I can string enough bulbs with this board to do approx. 50 amps at 3s. Higher and lower voltages will vary accordingly. I'm told these bulbs (12v halogen landscape bulbs- buy the 3 packs) will take 5s and blow on 6s. Now for a question- if I wire 2 bulbs in series and use 6 or 8s, will that work?
    Routed the grooves on the table saw, strung the 10 gauge wire thru the holes I drilled and removed the insulation from the top of the loops. Soldered the bare wire for durability. Alligator clips and wire come from Radio Shack test leads cut in half with insulated female spade connectors attached. Squeeze down one side of the connector to fit the bulb pins and you are all set. All readily available materials and inexpensive. Amp draw is easily dialed in to whatever you want. Bulbs generate lots of heat, so be careful- I just let them hang in the breeze, as it were. The E-flite meter gives you voltage, amps, watts and total mah used. And you can attach a meter to the balance plug and keep an eye on each cell if you like. And to give credit where credit is due, this wasn't my idea, I got it from an FPV flying web site.
    Fast Electrics Have A Small Carbon Wake
  • HydroMike
    • Oct 2011
    • 338
    Would this work OK for 2S ?
    • morewattsnow
      • Oct 2010
      • 236
      Just tried a 50% charged 7.4 Polyquest. At 7v 1 bulb drew 3.1 amps, so yes, I would say it will work on 2s.
      • 785boats
        Wet Track Racing
        • 3423
        Good job.
        I made a thing somewhat similar a year or two ago but using car headlight lamps. But now I use one of these. It's a balancer as well. Only 150W but it doesn't take long to discharge a pack. Plus, you can set what ever limit you want it to discharge to at the touch of a button.
        3 IN 1 Battery Meter/Balancer/Discharger LCD Display 150W Discharge from manufacturer , in category Lithium Polymer Battery ( Li-Poly, LIPB) Chargers, Battery Chargers & Battery Accessories.
        Cheers.
        Paul.
        • Spartanator
          • 1060
          I have my charger just discharge them at 2 amps, then charge at 4 amps. But for when I plan to run and it rains or something comes up I generally use this for 3s lipos and below:
          The guys who builds them and does all my soldering work is here: LINK
          • Doug Smock
            • 5359
            Yes sir,
            2 in series would be good for 24V, 3 in series 36v and so on.
            That should serve you well.
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
