pursuit battery placement
  • pugman2
    • 241
    ok I have got my build to this point. would it be bad on the hull to set adheasive mounted Velcro down the sides of hull for 2 packs without wood cradle or mount in center with straps . don't want to crack hull in rollovers . want to balance good. thanks
  • Luck as a Constant
    Make Total Destroy
    • Mar 2014
    • 1952
    I've done that with plenty of 2s packs, tho i wouldn't try with say, a 5s pack.
    • pugman2
      • 241
      thinking of running 6s
        Make Total Destroy
        • Mar 2014
        • 1952
        6s what? s or p? the difference is a 3s vs 6s pack. i might try velcro with a 3s pack, although thats pushing it for me. a 6s pack? no way
          Hey pugman2,
          What motor and prop ?
          And post some pictures of your setup.
          I have mine setup in the middle for better CG in a roll over.
          In all my testing with it that has only happened one time with a roll over,
          And that was from doing some bashing and jumping over a big jet ski wake.
          • pugman2
            • 241
            thinking o running 2 6s in paralel im not running the stock motor anymore . got a finished x447 a 1800kv lepard 4074 motor 180a esc with cooling mods im down to trying to find a happy place for esc and batts been going through pics and vids trying to get ideas for best placement looked at bling rocket build and alot of post trying to get ideas. havnt bought batts yet going to be getting soon ice is melted got to make up my mind between 5s and 6s going to give my nitro freinds somthing to talk about
            • pugman2
              • 241
              • pugman2
                • 241
                pics
                here are pics011.jpg012.jpg there is pursuit and one of my gas cat lol
                • pugman2
                  • 241
                  took me awhile to figure out pic posting on here dosent look like a can post in gallery or i dont know went there and was going to upload some pics and vids didnt see a attchment thing for that
                    The worst stress to the hull is the repeated mounting/dismounting of the batteries if you only use velcro. Had a DF 45" Sniper with wood cradle, running 12s2p ( 4x6s) , each battery has industial strength velcro the full length of the battery, bad idea. I can see the flex on the hull and eventually the hull was cracked. ( Boat was bought usedwith the mentioned set up)
                    I now first reinforce the area where I will put a battery tray ( CF or FG layer) and the velcro is only to prevent battery from moving, but use strap to hold them down. It's ok to have full length velcro on the tray but only two spots on the battery. I also never yank the battery to take it out, instead I run a credit card between the velcro and separate them.
                      Make Total Destroy
                      • Mar 2014
                      • 1952
                      A 6s pack strapped down to a battery tray, that's glued to the hull at certain points, using the provided tabs, will become stress points when the boat is bouncing around on the water if you want to get technical. reinforcing the area you want to put the batteries on IS a good idea.
                      Jmtc
                      • pugman2
                        • 241
                        would it be better to strap them on the center cradle that is already built on this hull think i may be able to stack and strap or put them side by side on it might have to change alittle stuff would have to mount esc on side of hull instead of in front of motor
                          Get rid of the deans plug,
                          And use 5.5 all the way in the setup or things will get hot.
                          I have mine setup with the esc the other way,
                          And I just run one 5000mah pack most of the time.
                          But I can run two packs to if I want for more run time and power if needed.
                          What mah packs are you thinking of using ?
                          Also I put pool noodle pieces in on each side and around the cells to buffer any movement,
                          That may come from a crash.
                          But most of the time I just strap the packs in and do my test runs,
                          And have fun.
                          How you drive has a lot to do with things to.
                            Make Total Destroy
                            • Mar 2014
                            • 1952
                            Well, considering I don't one one of those boats, nor do I know how big the interior is vs the size of two 6s packs, my first instinct would be to run a couple of carbon trays across, or buy smaller mah packs.
                            • pugman2
                              • 241
                              5000 mah lenny if i run singles what kind of runtime would be safe im running simaler set up to yours motor and prop wise
